What is the feed voltage?
right now I'm feeding 155v to the circuit, that's adequate, I want it regulated. if some volts will be consumed or missed in the regulator, I can wind a new tranfo, 200volts for example.
You can use the Simple series reg, it has been tested from less than 100V to a few hundreds volts (and simulated at up to several kV). It drops a few volts, but rather less than comparable alternatives.
I have also described some LDO HV regs, but they either require a PMOS, or regulate the negative rail
uh that sounds good. is there any schematic or link or thread or something about what you told?
Here you are:uh that sounds good. is there any schematic or link or thread or something about what you told?
http://www.diyaudio.com/forums/power-supplies/198986-simple-hv-series-regulators.html
