Hi all.
I have accquired a phenominal driver. It's the Royal Turbomax 900. Here's the TS Parameters for you to hae a look at.
Dia: 370mm. Re: 5.8ohms. Fs:36.60Hz. Qms: 7.84.
Qes:0.47. Qts:0.44. Mms:193.92 (g).
Cms:0.10 (mm/N). Vas: 157.43 Litres. BL: 23.55 (N/A).
L1K: 3.16mH. L10K: 1.16mH. Xmax: +/- 24mm.
Po: 900 watts AES. Sd: 1369cm2. Vd: 6571cm3.
Couldn't believe the Vas when I measured it so did it twice. Came out the same. I'll let you know how I get on with it.
Ricky.
Ricky.
