i read up on the 2500 and i will order a pair and see how they respond. thank you guys
hi brian , would you be able to tell me what the difference would be with the cabs if the wood in the middle of the cab, the one that comes down from the top 11 inches, if this was 13 inches long instead of 11?
how much would this affect the tuning of the cabs?
thanks in advance
which measurement tool is recomended?
akabak, hornresp or something else?
thanks in advance
Hi Pabesco, just wondering how your project went.
Did it live up to your expectations? Do they go low enough for your purposes?
How is the quality of sound, pertaining to peaky-ness or overdamped.
Just wondering as I think a BVR/ mini scoop is what I want to build for my next project.
hi guys, i know are passed some year from these conversations but i'm tring to design 2 back horn loaded whit hornresp and these conversation give me some answers and a question
why did you apply an HPF? for reducing the displacement of the speaker? in these case if i have a preamplifier and he got a cut like in the picture i don't need these HPF?
thanks
thanks
No image shown, so used the 'insert image' option:
The HPF normally is to protect the driver down low.
thank you GM for the advice.
then is correct say there is an HPF at 30Hz in my preamp? can i consider my driver in safe also if the Xmax is out of the limit under 20/25Hz?
You're welcome!
I don't know; I mean that historically it would be a separate device and/or built as part of the XO, but I haven't kept up with the electronics for decades now, so check your manual.
Only if there's very little signal below ~30 Hz as excursion is increasing at 4x/octave.
