Do you take that entire geometry that I’m describing it cut it down in that same event will happen at 430 Hz. The fundamental tuning of 144 instead of 28.8? I might be off of that it’s not like you just cut them in half or multiply them most the time is shuffled in staggering theorem 30 6090 it seems because that’s how you find the speed of light versus the ratio two to one using the exact dimensions of the sun or seconds in a day on earth location at onI might be off of that it’s not like you just cut them in half or multiply them most the time is shuffled in staggering theorem 30 6090 it seems because that’s how you find the speed of light versus the ratio two to one using the exact dimensions of the sun or seconds in a day on earth location at half to speed of light, but its orbit or radius you are looking at either one Either one so we certainly have an element of frequency they’re just like we do wanna swan paddle him in one second which is exactly 30° or 15 twice you lift it up and you get that exam exact result and it’s 500 seconds to read I like to register earth and it’s half a second I need side of that ideEither one so we certainly have an element of frequency they’re just like we do wanna swan paddle him in one second which is exactly 30° or 15 twice you lift it up and you get that exam exact result and it’s 500 seconds to reach Earth 1000 to reach and achieve the speed of light by definition?
Oh that down to one second this is a swing on a pendulum it’s all it is it’s a proportion that we can use? Why is it hidden in centimeter/foot Numbers it is everything is.
If I’m not mistaken then we will find it again in the other direction and it will be associated with lower frequencies not higher 1720? Threshold for frequencies that seem to also follow the octave thing or the spread of harmonics in between to use that probably confusing sounding hard enough to say or try to tape however 860 is a threshold for the 28.8 Hz pipe which is 360 long which is 24 Hz however you gotta give up an endpoint to swing the pendulum and that’s 30 cm from east side so you’re at 28.8 in a parallel pipe and you must exit at 270 and 90 from either end as well that’s two 486Threshold for frequencies that seem to also follow the octave thing or the spread of harmonics in between to use that probably confusing sounding hard enough to say or try to tape however 860 is a threshold for the 28.8 Hz pipe which is 360 long which is 24 Hz however you gotta give up an endpoint to swing the pendulum and that’s 30 cm from east side so you’re at 28.8 in a parallel pipe and you must exit at 270 and 90 from either end as well. 240 and 60 well that’s 36 Hz and 144.
If you’re not seeing a pattern don’t worry you’re just not looking hard enough and I’m not typing it or doing it justice, I don’t think anyone can. We/ I need to look if you’re interested there’s a gold mine sitting right there for everyone to see.
