Hi
I have 2 320A16A B&C Speakers
Iwant a ampli circuit that give 320w rms for 16 Ohm output
Help me please
thanks
Bye
Help me please
thanks
Bye
V_nadaf said:Hi
Help me please
thanks
Bye
Why does it need to be 16 ohms ?
That would mean a very high pwoer supply voltage to get 320WRMS !
8 or 4 ohms would be a much better impedance.
320W into 16r requires an output voltage of 101Vpk into your load.
That will require supply rails >=+-110Vdc.
This will be quite a challenge to build and potentially lethal.
Take care.
An alternative would be to build a bridged amplifier for each speaker. This will requires two amp channels for each speaker and each rated at 160W into 8ohms. Very achievable. Note that the 160W amp can just use 63V capacitors if you use a 40-0,40-0 transformer. Whereas the 320W amp will require >=125V capacitors that will be very bulky and very expensive and very dangerous.
Take care.
andrew is right
andrew is right as usual .....
elector circuit rings a bell ....but i am not sure about this i have to dig and get back to u
