160va dual 24v toroid for lm3875?
Datasheet just has 8ohm specifications:
DESIGN A 40W/8Ω AUDIO AMPLIFIER
Given:
Power Output 40W
Load Impedance 8Ω
Input Level 1V(max)
Input Impedance 100 kΩ
Bandwidth 20 Hz–20 kHz ±0.25 dB
Equations (5), (6) give:
40W/8Ω Vopeak = 25.3V Iopeak = 3.16A
Therefore the supply required is: ±30.3V @3.16A
The build manual from audiosector says:
"When looking over the curves a speaker with a nominal impedance of 4 ohms tend toward 25V rails with a reasonable margin of safety, while voltages above 35V are still well within the range for 8 ohm speakers. This shows that transformers with 18-22V secondaries are well within reason for many common commercial and DIY speakers. A transformer with 25V transformer secondaries can also be successfully with less of a safety factor."
On page 10, graph Output Power vs Supply Voltage has curves for 4, 6 and 8 ohm speakers. 6 ohm shows a max output at 33V before falling off, so less than that is a good idea.
A 22V transformer would give you about 31V rails, which is what I would go with as long as you aren't intending to run 4 ohm speakers with it in the future. That voltage will work quite well with 8 ohm speakers if you want to use those at some point.
