Watch the following YouTube video (it's about spectral analysis of the 1985 digitally-recorded Beach Boys album, which was released on vinyl):
YouTube
The vlogger concluded that post-22khz content is "inaccuracies in vinyl" or "cartridge mis-tracking".
But I'm not sure I buy that. For one, he did not repeat the experiment with another turntable/cart. Or he didn't attempt to re-align the cart. Etc. ,etc.
What could be some reasons for the post-22k ultrasonic content shown in the video?
YouTube
What he said plus some vinyl noise and maybe some audio frequencies AMed by the flutter. If you think this is caused by the digital recording your wrong.
A 44.1kHz digital signal converted to analogue would only have post-22k content if the system was faulty, either by design or accident.
Why reject the obvious explanation?
Are you going to help dispel my confusion? You could explain to me which aspect of digital audio I am confused about.
Post 22KHz COULD be a poor reconstruction filter on the cutting head DAC, some of the early digital stuff was not exactly brilliant in this regard.
However I would tend to be suspecting mechanical issues with the scope trace scratched into a plastic disk first.
Was it just me or was the audio hitting that zoom recorder WAAAY hot?
Regards, Dan.
Regards, Dan.
I inquired about that on a pro-audio forum. I.e. ,what kind of filter pro DACs (of that vintage) used. No one seems to know. Someone did comment that the cutter was rolled off after 17k (regardless of source) as that prevents it from burning out. Ergo, maybe no reconstr. filter used (???).Post 22KHz COULD be a poor reconstruction filter on the cutting head DAC, some of the early digital stuff was not exactly brilliant in this regard.
In the "mechanical domain", the stylus/cart. could resonate those overtones (harmonics). But what the vlogger shows is a lot of "noise".However I would tend to be suspecting mechanical issues with the scope trace scratched into a plastic disk first.
Anyway, an easy experiment to confirm that would be to record the CD release of the same album (or any digitally-recorded album of that vintage (e.g. Telarc)) onto a good cassette or open-reel deck. Digitize that at 24/96, and repeat the spectral analysis.
BTW: The software used in the video is Adobe Audition 1.5.
Got to admit that mess looks as much like intermod as anything else?
It would be interesting to have a disk cut with pairs of non harmonically related tones at varying levels, you cannot see intermod on a single tone but it becomes VERY obvious with two non harmonic ones.
If the cutter amp is rolling off at 17k or so then the mess above there can only be cutter mechanical, record and replay chain issues.
Audition would not have been my first choice for this, matlab is much better at this sort of thing.
Microphonics. Just watched it again. Watch the part at the beginning of the record play before the music. Look at all the high freqs when he hits his computer keyboard!
Intermodulation
Did you/anyone watch the original Lp vs. CD video made in 2012 by another vlogger? The video in my OP was the vlogger's reply to this:
YouTube
That would appear on the output of a CD player, too. But it doesn't. (????)Got to admit that mess looks as much like intermod as anything else?
...you cannot see intermod on a single tone but it becomes VERY obvious with two non harmonic ones.
YouTube
He lost me at "People say that records have "better" frequency response than CD..."
I just didn't see any point in going further.
Mike
Mike
They do. 40 kHz or more one of the few if not only advantages.
OK...phono is capable of higher frequencies, but is it flatter response, lower distortion or lower noise? No. Not better.
Mike
Errrrrrrrrrr...........
For phono preamps, check out ChannelD's Seta model specs ( DC to 4,000,000 Hz ):
CHANNEL D - Seta
If one wants to criticize phono, go for something like S/N, dynamic range, etc.
Many MC carts, phono stages, preamps, and amps can have extended and flat specs. E.g., My Ortofon MC from the early 80s has: 20 Hz to 40 kHz, +4,-1.5 dB.OK...phono is capable of higher frequencies, but is it flatter response, ...
CHANNEL D - Seta
I did.
Mike
I did.
Mike
Did you read what I said? This is not news and dosnt have anything to do with the OPs question.
Extended response is the ONLY thing that exceeds CDA capabilities, that's where it ends, and the response is not really that flat either. In all other ways, phono is inferior, IMHO.
Mike
Mike
Much much more likely that a proper reconstruction filter was used in pro gear. A cutter rolloff would be much more gradual and fairly useless as a reconstruction filter. Therefore, most likely that both fillters in use.hollowman said:I inquired about that on a pro-audio forum. I.e. ,what kind of filter pro DACs (of that vintage) used. No one seems to know. Someone did comment that the cutter was rolled off after 17k (regardless of source) as that prevents it from burning out. Ergo, maybe no reconstr. filter used (???).
Surely noise is what you expect when you drag something against something else? Where do these "overtones" come from?In the "mechanical domain", the stylus/cart. could resonate those overtones (harmonics). But what the vlogger shows is a lot of "noise".
Maybe that is because the CD record-replay system is very linear? Hence it has very low levels of harmonic distortion and very low levels of intermods.That would appear on the output of a CD player, too. But it doesn't. (????)
Y'all might wanna check out Rob Robinson's RMAF vinyl-ripping presentations on YouTube.
Some info here:
Analysis of Vinyl Frequency Content
Some info here:
From nowhere, actually. I made everything up. Fake news.Where do these "overtones" come from?
- Analogue Source
- 16/44.1 digital recording (on vinyl): source of ultrasonics
