While blundering through some sources on the internet, I ran across Qkits out of Ontario Canada. They distribute the "Futurekit" line, out of southeast Asia.
I ordered two of the FK607 units, listed as 15 watt amplifier stages. they are based upon the TDA2005 chip, and I am quite pleased with the quality and ease of assembly, it comes with what I would consider an excellent heatsink, and the little circuit boards will become the power stage of a twin 15 watt amplifier I am building.
HOWEVER, the schematic included with the kit is wrong! With this post, I have attached a pdf of the original schematic (redrawn for clarity, with the errors as published.) I will attach a pdf of the corrected schematic on the following post
fk607 corrected schematic
I have attached of pdf of the corrected schematic for the FK607 assembly - borne out by tracing the circuit paths on the circuit board.
Future kit claims in this configuraqtion, the voltage gain is 30. In my next post, I will show the pdf that includes the modifications I made to the circuit, which boosted the gain to 40, and improved low end response.
FK607 Mods
Attached is a pdf of the FK607 15 watt solid state module that I ended up building, with the modifications I made to the circuit.
Specifically, I ran a wire rather than the 4.7 k "R1" in series with the input, and changed the 1.0 uF C5 input capacitor to 2.2 uF.
The circuit as modified has a voltage gain of 40.
I found the modules at Qkits.com
Just thought I'd throw this out there, I can use these modules and the "stereo" version in a current and some future projects stewing around in the back of my mind! ( I know, 15 watts isn't a LOT of power, but it is enough to suit my needs - and the price was good too!)
😀 Cheers!
😀 Cheers!
oop!
Sorry, folks, looking at the pdf's I see I left the value of one of the zobel network resistors out - they are both 1 ohm 🙄
New to this site and found it as I was looking for a schematic for this kit.
I am using the amp kit in a DIY TRF AM radio using the MK-484 AM chip. I removed the 10K volume control as I am using a 100K panel mounted control. I will try the capacitor mod and see how well it improves the bass.
