15000 uF capacitors?
15000 uF
I am sold on the Panasonic TS-series of aluminum electrolytic caps. There are several sub-series, like TSNH (long-life and high ripple-current, low-ESR), TSU (85C general purpose), TSUP (mini-size 85C), TSHB (105C, hi-voltage, long life, low-ESR, high-ripple) and others. All are snap-mount, so if this is not what you need, you might want to check out the Panasonic screw-terminal caps.
My favorite is the TSHB for the high-voltage section of most AC-DC SMPSs. For the low-voltage sections (63V and lower, I like the TSHA series.
Just my $0.02 worth,
Steve 😀
Paralleling 2 caps of hald the value. might actually end up being smaller, or might at least might be easier to fit into limited space. Two smaller caps are also a lot easier to find. Performance should be the same. The voltage of each would have to meet the voltage you mentioned though...
rmihai said:
Hi all,
I need one pair of the BEST 15000 uF capacitors, but first of all I need them to be as small as posible.
Any idea where I can find such a thing?
Thank you
Those are two incompatible requirements!
Any way the best caps i can think of, are the ELNA "for Audio" (LPO series) but i think the largest capacitance is 10.000uF (63V)
Check them out, they are great for their size.
The Panasonic are also a great choice
Apex Jr said:
Tony and Group...
They are now up on the website... www.apexjr.com
and priced. Listed on the New Arrival Page and the
Radial Cap Page...
Here's the link to a picture of the 22,000 Uf 100V
New stock made by Hitachi
www.apexjr.com/images/CAP22KMFD.JPG
Steve
wow! 105*C caps, do they come with clamps? and are you accepting payments via western union?, that is the only means avaialble to me.
