15" Home Theatre Passive Subwoofer (local pickup only in Fullerton/OC/LA)
Asking price $300 (OBO)
Dayton Audio 15" Reference HF Subwoofer 4 Ohm in custom built box made of reinforced MDF, surface is white laminate. Currently has removable corner guards (seen in picture) because of our kids, but we can remove when sold. Also has a removable seat topper for decorative look and use if needed as seating in home. You can have with unit or not, your choice. Specifications of passive (requires external amp) subwoofer can be seen in photos, and also dimensions of unit.
Must be able to pick up and have a vehicle that it will fit in. Local pickup only in Fullerton/OC/LA
Highlights of subwoofer:
-Engineered to provide high volume, low distortion bass in larger rooms and other highly demanding applications
-Extensively vented motor eliminates compression and allows quiet excursion
-Lightweight black anodized aluminum cone for rigidity and lower moving mass
-Triple shorting ring motor for ultra-low distortion
-2-layer coil for reduced back EMF
-Suitable for sealed or vented enclosures
