140V miniature power supply
Not exaclty.
Please refer to page 6 of the datasheet, where you can see the MC34063 driving an esternal transistor.
OK, at the schematic on the datasheet the driver transistor is connected to switching node, so the limitation is here. One surely could rearrange it so that no pin of MC34... experiencesanything above 12V.
Off topic: how did you rectify 4,5kV? series thyristors? SiC diodes? thyratrons?
You could use a dual-primary transformer rated at, say, 30V+30V, then wire the primaries as if for 110V, but connect it to 220V. Wire the resulting 60V secondaries in series and you have 120V. Then it's just a bridge and an LM317 and a few parts to bring it down to 100V.
It would work for a few seconds until the transformer fails. Doubling the Voltage will likely saturate the core and the current will go way up and fail.
Explained here. Look for 'Circuit Effects of Saturation'
Understanding Transformers: Characteristics and Limitations
Is this too large?
http://www.antekinc.com/pdf/AS-05T120.pdf
What about using a 220 to 24 transformer then run the 24v into a the secondary of
a 220 to 12 transformer to get about 110 vac. But are you sure you can't find any small 220 to 110 transformers or even a small 220 to 440. Or you could use a 220 to
55 or 60v transformer and use a voltage doubler.
Here are a few links to help you. You should be able to tweak
all of them to output 140V.
Nick DeSmith design is one of the most efficient ones, based on
the MAX1771.
Mike Mooress (threeneurons) has an excellent MC34063 design.
Tayloredge is one of the best ones you can pick ready made.
John Taylor also put up a nice comparison of nixie supplies available.
Nixie HV Switching PSU
Nixie Stuff Threeneuron's Pile o'Poo
Mike's supply on ebay -
http://www.ebay.com/itm/150642015998
Tayloredge - Smart Nixie modular display system
http://www.tayloredge.com/storefront/SmartNixie/PSU/comparison.html
Tayloredge - High current nixie power supply
