I came across a headphone tube amp running on 12 volts. I'm skeptical about how it would sound as the tube is running in what would normally be considered a non linear range. It is easy to build and maybe someone could comment on how it sounds !
There is also a link to a US NAvy Lesson on tube operation. I haven't read it but it might be interesting to go through it sometime.
Here are the links.
http://diyaudioprojects.com/Solid/12AU7-IRF510-LM317-Headamp/
http://diyaudioprojects.com/Solid/12AU7-IRF510-LM317-Headamp/US-Navy-NEETS-Module-6.pdf
Here are the links.
Here are the links.
NP-100v12: DIY 12AU7 (ECC82) Tube / IRF510 MOSFET Headphone Amplifier
The 12AU7, 12FK7, and 12FM7 tubes are 12V tubes, originally designed for automotive radios. The Millett Hybrid MAX and the revised MOSFET-MAX are similar DIY designs that can use the IRF510/9510s as output buffers.
12AU7 ( ECC82 ? ) is a 12 V tube , but that is only the heater voltage.
The operating voltage on the anode is usually much higher than that. Closer to a 100 or so volts. The operating point with very low anode voltage will be in the non linear region . Can anyone who has tried this circuit tell us how 'audible' is the associated distortion ?
Cheers.
Cheers.
Cheers.
Oops. Sorry, hadn't had my coffee. I meant 12AE6... I don't think I'd run a 12AU7 at 12V.
