I've been in an apartment, away from all my heavy duty toys (table saw/drill press/etc.) and have been buying parts instead of building stuff. I'm probably going to be buying a house soon, so I thought I'd start putting together some building blocks. Using parts I already have, looking at data sheets and other plans online, here's what I've come up with for a +/- 12v regulated power supply. I think it would be more than ample for opamp based preamps. What do you think? I thought I'd get expert opinion before I applied solder to anything ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks!
Tom.
Thanks!
Tom.
luka said:Hi
I think it all looks good, no need to use MUR, 1N will do fine, I would use maybe 13 or 14 on secondary of trafo to really have good regulation even if primary in not that stable...
you could use even more simple design, with 7812 and 7912, what do you think?
The values shown are because that's what I have
Thanks!
Tom.
Huh that was cheap, wanna traderenfrow said:I bought like 500 of the MUR for $14USD.
The lm317/337 are quite a bit better than the 7812/7912.
Just be careful how you lay things out on your pcb/protoboard. The sense ground of the lm317 should not contaminated by the charging current of the big caps.
I second the trimmers for a versatile supply. If you want to go for a fixed supply, you could also replace the bottom resistor for a zener+1n4148 (for rough tempco)
- Power Supplies
- +/- 12v regulated power supply review needed
