New in box: 230VAC to 12VDC external linear power supply, ultra-low noise. Voltage is fine-tunable with a screw on the back side. Maximum current is 2A. Asking price: € 70, shipping from The Netherlands.
Outputs:
Weight: 1,1 kg
Also available in 5V.
Image uploads are somehow not working, here are the pictures:
Outputs:
- 2x 5,5 x 2,1 mm jack plug
- Talema transformer
- 4x high speed diodes
- Philips filter capacitors primary side
- Panasonic FC and Siemens filter capacitors secondary side
- includes EMI filter
Weight: 1,1 kg
