A nice 10uF paralleled with a 2uF or 2.2uF should do ya.You can parallel any cap values to achieve 12uF, you know, right?
https://www.speakerenco.nl/filterSearch?q=12 uF but I don't know if they still send anything to the UK after the Brexit.
5% tolerance
https://www.tedss.com/2020121290
10% tolerance
https://www.tedss.com/2020039762
(these are at 100V, should suffice for most crossovers.
10% tolerance
I'd go with these, find something cheap to add that brings it over £20 exc vat for free delivery.
Bargain for PP caps made here in the UK.
https://cpc.farnell.com/ampohm-wound-products/fp-ca-12-au/audio-capacitor-12uf-630v/dp/CA06099
I could sell you a pair of 12uF NOS Siemens MKV caps, industrial quality hermetically sealed ceramic feedtrough connection bolts,
for €60 shipped to England.
The data below is for the 15uF caps I also have, but the 12uF is not much different.
I have at least 10 of those, if someone else is interrested, also 4.7uF.
I can also measure and look for a pair if needed.
Siemens B25838
MKV
15uF +-10%
Ueff 800V
Un 1100V
Imax 80A î 9 kA Is 23 kA
(du/dt)max 600 V/µs (du/dt)s 1500 V/µs
Lself 170 nH
tan δ0 2 · 10–4
RS 1,7 mΩ
Dimensions ∅ × l = 89,3 mm × 194 mm
Approx. weight 1500 g Impregnation Oil
Fixing Threaded bolt M12 Max. torque 10 Nm
Terminals Screw terminals M10 Max. torque 7 Nm
Terminal cross section 16 mm2 Creepage distance 20 mm
The one on the rigth in the picture.
Siemens B25838
MKV
15uF +-10%
Ueff 800V
Un 1100V
Lself 170 nH
tan δ0 2 · 10–4
RS 1,7 mΩ
Btw, this is the only time i offer those 2 caps for this price as introduction to this very high quality caps.
In return I would like the buyer to report back about theyr sound so others would also hear about it.
I can guarantee those caps are no disappointment 🙂
Those are great caps indeed.I'd go with these, find something cheap to add that brings it over £20 exc vat for free delivery.
Jantzen Standard Z-Cap 12,00µF 400VDC 5% MKP dia-22 / 46mm. hor. 7.89€/pcs
shipping to England 8€
PM if Interested
PM if Interested
https://www.ebay.co.uk/itm/25622971...ar=556237459701&widget_ver=artemis&media=COPY
Monacor MKPA 250v for £6.60ea
Update,I could sell you a pair of 12uF NOS Siemens MKV caps, industrial quality hermetically sealed ceramic feedtrough connection bolts,
Siemens B25838
MKV
15uF +-10%
Ueff 800V
Un 1100V
Lself 170 nH
tan δ0 2 · 10–4
RS 1,7 mΩ
Only 4 of those 15uF 1100/1400V caps left
