Unless there are about 24 two inch fins, these heatsinks are half the size required for a 270W SuperAmp.
Should you be asking first instead of hooting? If you had no intent to know further, please do not bother.
Touting these as suitable for a Leach SuperAmp without publishing the specs is most suspicious. Doing so without knowing the required specs is just plain lazy. Shipping from HKSAR would likely be cost prohibitive for most folks. You really expect us to call you in HKSAR?🙄
