Heat dissipation and accuracy are all the rave with todays highly portable processors but for basic processing like over and under voltage protection say switching on the power to the main trannie if voltage is either between 80-145volts or 180-290volts and auto selecting primary windings configuration if voltage is above 145volts one can use 12volt logic rather than 3.3volts.
