12" XLS with 2 bxp10 PRs
Hi all,
I would like to know if someone could review this design. I am planning on using 2 BXP10" PR with 1 Peerless 12" XLS. I modeled the design in Unibox in 40 Liters box and total weight of 600 grams. The results will be flat to 25Hz and an F3 at 22.
The specs for the PR: Sd 308 cm^2, Fp 16 Hz, Mms 226 gr, Cms 0.43 mm/N, Vap 56 l, Q 3, Xsus 22mm one way.
bxp10 Specs
I will also be using the 500 watt PE plate amp.
Thanks in advance for your input
Rajiv
