hey guys, looking for a killer 12 and 15, something in a ported enclosure that will shake the foundation of a house and still sound killer for music. looking for a 12 and 15 that will work in a smaller enclosure upto 3 cubic foot for each driver
thoughts, recommendations. will be using with a dayton dsp 1200 watt amps
you will have to sacrifice bass extension if you want house shaking SPL in such a small box. Try 2*B&C 12TBX100 in 60L with a 300cm^2 port tuned to 43Hz. That will do 123dB down to 40Hz. here is a hornresp record:
(save a .txt and import into hornresp)
there is also the BG100 if budget isn't an issue. In the US the lab12 may also be worth considering.
ID=48.20
Ang=2.0 x Pi
Eg=70.00
Rg=0.00
Cir=0.00
S1=0.00
S2=0.00
L12=0.00
F12=0.00
S2=0.00
S3=0.00
L23=0.00
F23=0.00
S3=0.00
S4=0.00
L34=0.00
F34=0.00
S4=0.00
S5=0.00
L45=0.00
F45=0.00
Sd=531.00
Bl=25.50
Cms=9.38E-05
Rms=4.60
Mmd=110.20
Le=1.60
Re=5.10
Nd=2P
Vrc=60.00
Lrc=25.00
Ap=300.00
Lpt=57.00
Vtc=0.00
Atc=0.00
Pmax=2000
Xmax=9.0
Path=0.0
Mass=0.00
Re'=0.00
Leb=0.00
Le=0.00
Ke=0.00
Rss=0.00
Rms=0.00
Ams=0.00E+00
Fr1=0.00
Fr2=0.00
Fr3=0.00
Fr4=0.00
Tal1=100
Tal2=100
Tal3=100
Tal4=100
Comment=BC 12TBX100_8O portable box
FILTER
0 0.01 0.0 -1 0 0.01 0.0 -1 0 0.01 0.0 -1
100 25 38 0
4 30.50.5
0.50.50.50.5
SSSS
0111
2041
0022
1111
111
100
I would move up to an 18" for 3ft with a couple passive radiators per driver tuned low.
Something like this or the Lavoce equivalents.
B&C 18TBW100-4 18" Professional Subwoofer 4 Ohm
Also more expensive options if you wanted even more output.
This will get you the best of both worlds.
