I want to build a preamp using one of the above tubes. The 45 I’ve heard is highly microphonic:
Are any of the others lower/ low in microphonics?
Rick
The 45 is midly microphonic. Not much
10y is not microphonice maybe slightly.
27 is microphonic
26 is the momma of microphonic.
I used all so the power tubes in my exprience is midly only.
With microphonics just have a subchasis with plastic pcb standoff supporting it and you should be fine
REgards
NIcholas
27 is microphonic
REgards
NIcholas
If I understand you correctly, you used them in power amps, which would not fully reveal their microphonics, vs in a preamp - where microphonics are multiplied “100” times”.
However the technique could help, would it help enough in a preamp?
I used all in preamp.
What i meant that i tried the power tubes in preamp segment and i find them not at all microphonic
SOrry was a rush response
My 26 and 27 are both balloon. UX226 and UX227. THe 227 i have is mesh.
Before this technique i could talk to my 26 and ith will respond thru the speakers. Also what happens the sound has a rush and echo feeling due to the mechanical feedback applied to the 26 as the sound is hitting the glass like a microphone.
Don't worry about 45 or 10y this are not that hard to get right
Cheers
nIcholas
Cheers
nIcholas
If you are considering dht don't waste time with the idht brothers. They are far inferior to the dht brothers unless you do not have the time to troubleshoot and debug the microphonic and hum part of the dht
Thanks Nicholas!
So (newbie here) the dht are only the 45 and 10y; while the 26, 27 and 12B4A are idht – so if you think you can debug the microphonic and hum, go either 45 and 10y??
Cheers
Cheers
Rick
Apologies if i confuse you
26,45,10y are dht
27,37,57,76 are old skool dht
the rest 9 pins and 7 pins
If possible avoid the 9 and 7 pins
Go for either 26 or 27. 45 and 10y not worth the effort. But you gain bragging right. 10y get the thrioated fillament like vt25 or 801a. this has very sparkling highs but no enough bass energy and mids. vt25a like western e's ceramic base is good balance but can't come close to the 26.
26 is a pain in the **** to make it work. 27 is not to far away in sound but easy to work with. Not popular as the voltage is 2.5volts. It sounds better than 37,57 or 76 because the fillament current is 1.8a. 26 sounds better than 01a because fillament current is bigger. Moral of the story is to go for high fillament dht as they sound more fuller
Cheers
nIcholas
26,45,10y are dht
Cheers
nIcholas
Hi Nicholas
You are *very helpful * : )
Here is a 27 circuit described as “If you don't have to drive long cables (>50cm), this is the way to go” http://www.dhtrob.com/schemas/afbeeldingen/vv227lun.gif
As the preamp is to use in a very high gain (horn) system, I might well use DC Filament per TentLabs Supply www.tentlabs.com/ProductEntities/HeaterSupply/HeaterSupply.html
Can you suggest a simpler/ better 27 preamp circuit?
Thanks kindly
Thanks kindly
I use the 26 in my dht based transformer coupled pre-amplifier design which you can find on my site. It has been through several iterations and has improved considerably. It is silent and microphony is quite tolerable now as well. My approach was to make the chassis heavy and rigid, the tubes are not isolated mechanically from it, however I think mechanically isolating the sockets on elastomeric bushings on a separate subchassis is an excellent idea.
The 26 is extremely microphonic as are the 12A and 01A - all of which I can recommend in pre-amplifier duty if you can deal with the microphonics, and noise pick up issues.
Although not pretty electrostatic shields around 26/01/12 type tubes helps a lot with stray fields. I used copper foil for mine.
I recommend you read my article if you are thinking about building any sort of DHT based pre-amplifier.
I also like the 27 IDHT triode as well. Have designed several circuits using this for others. Watch out for the cathode insulation issues in early ones. I have both mesh plate globes and solid plate st types, both sound quite good.
I don`t agree here
1-I used both 26 (4 different brands) and 01a (3 different brands) in the same preamp with same system. And the best is the 01a by a good margin. The 26 is way too much focused on voice, you miss both extreme (but they are there)
the 01a is more detailled, have mores sparkle and doesn`t emphasis on voice.
2- most on the people and I will say that a 45 sound better than a 2a3 even if the heater current of a 45 is smaller that the one on the 2a3.
I`m not sure that the more heater current, better the tube.
It may work sometime. the 26 vs the 112A (same tube with different heater current). The 26 sound more open and dynamic.
I’ve just read Kevin’s excellent article “DIY a 26 DHT Preamp” http://www.kta-hifi.net/projects/pre_page/26DHTPre/26dht.html.
The attention to detail, discussion of options, numerous warnings etc etc (and similar comments made elsewhere) give me the very strong inclination to do this design.
I know an excellent local tube dealer who has no 26 tubes, but 10y tubes. Would much be involved in adapting Kevin’s design for a 26 or 01, to a 10Y?
I think the most relevant characteristics are:
Tube Filament Plate Resistance MU Bias Ip
26, 1.5 V @1.05 A, 8000 Ù, 8, - 9.0 V, 7 mA
01, 5.0 V @0.25 A, 8000 Ù, 8.5, -9.0 V, 3 mA
10Y, 7.5 V @1.25 A, 5000-6000 Ù, 8, ?, 18 ma
Gain aside, how close are 26 and 10Y sonically?
Has anyone had the same experience as Nicholas:
“10y . . Very sparkling highs but not enough bass energy and mids”
I used 112A, 26, 01a, 10Y and 801A in my dht preamp (as weel as other iht but they were not as good)
the 112 sound a little closed compared to the 26. You don' t have hum issue but overall sound is not that great
26 is a good performer but miss a little spark. I don' t like overall character, too much emphasis on voice.
10Y, very good performer. Big sparkle and way cleaner sound. The only thing is that the bass seem to miss. The preamp measureed well above 26 spec but we miss a little something on bass. (F3 was 16Hz from memory)
801a (most expensive), nearly as good as the 10Y (same tube with bigger plate dissipation) but just a little less clean.
The best result I had with 10Y/801a were with a small EQ (between input and the grid) that boost the bass area by about 1.6Db.
01a, very good, a solid bass, somewhat less clean as the 10Y but better bass. Sparkle is good, better than the 112A or the 26
It' s hard to choose between 01a and 10Y so I made a switch in my preamp to use both and switch in less than 30seconds.
But I can say that 80% of the time, the 01a is playing
I keep 10Y for classic guitar, violin concerto or opera where no real bass is involved
Sadly, I couldn' t try 71A, 45 or even 2a3 in preamp position for direct comparaison since I' m running out of gain🙁
etalon90
> Sorry, poor English
It’s clear to me, thanks!
> 10Y: . . The only thing is that the bass seem to miss
A little similar to what NickC found, but how was the 10Y in the “instrument range”, from say 35 hz up?
Cheers
> Sorry, poor English
Cheers
I use (and love) 801A. Bass is not a problem with this tube IMHO. It depends on the load probably. OH! Microphonics? Not a problem.
Ciao
Gianluca
Ciao
Gianluca
Kevin
The primary aim of your 26 DHT Preamp was to accurately assess the virtues of direct heated triodes in small signal applications, and you were very happy with the results.
On reflection it seems somewhat more complicated than it needs to be (eg 30 parts). Also therefore more expensive to acquire all the parts (I started looking last night).
Any comment on simply using a cathode resistor and bypass capacitor? And to help minimise hum, a TentLabs DC Filament “Directly Heated Tubes Supply” www.triodedick.com/tentlabs/Triode Dick heater UK.pdf
Cheers
Cheers
Just a tip if you're building a DHT pre; don't do as I did and mount spring switches and rotary switches or other switch-based components on the chassi of the DHT. I use 12A in my HF/pre-amplifier, a brother of the 26 but with battery friendly filaments, and they make incredible microphonics when you flick a spring switch mounted on the chassiplate where they are mounted.. I have to lirk them not to make Bubba Microphonic.
Unless you choose to use a potmeter without steps, I'd say keep the pre passive stage outside the DHT's chassi (that is, if you can drive the cables to the DHT passively - short cables or TVC.) or use for example more wood in the construction, to dampen it better.. Just remember you *will* hear any vibrations unless dampened.
And ofcourse the most important lesson in DHT: keep the filaments clean!!! (Either very well regulated with current reg and $$$ of black gates or simply a SLA battery with a dedicated charger, per tube)
I should add that ofcourse the flick vibration issue doesn't affect sound while listening and not flicking around on anything. And the boings and dongs do sound interresting in it's own way but in case you doubt, it is annoying. very. I'm not listening with very loud & deep bass but I would certainly expect it to be a mechanic feedback problem with DHTs in driver tasks. As indicated earlier in the thread by someone else, DHTs as output tubes are one thing, it is something quite else if the microphonics from the DHT are amplified n times. DHT microphonics can be minimized but not eliminated I think unless you have the DHT amplifier in a separate room perhaps...
hmm thought I should add that my chassis is all aluminum and very prone to vibrations (with the amp off, you can even hear the alu plate vibrate when flicking the switches). Dunno how it'll work in a better chassis and with weaker springs in the switches.. This is a 12A/71A integrated and my first DHT amp, so my DHT experience is limited.
- Tubes / Valves
- 10Y, 26, 27 and 45: relative microphonics
