Amplifier is 250K Z with variable gain... I use it at full gain 30V.
Speakers are 100db.
I use both dac (2.0v) and phono (cart 4.0 mv and phono stage 330 output z) as my sources.
I am currently using a passive preamp with a 10K input z. It works well, even on phono.
I would like to purchase a more robust pot though and I am wondering if I should change the value to 20K and what the effects would be if I do so.
Speakers are 100db.
20k instead of 10k means slightly less distortion in the source, and slightly more HF rolloff from the cable. It is extremely unlikely that you will notice the difference.
