10F vs W3 bamboo vs W4 bamboo vs Mark Audio for mid tweet.
I want to employ a 3”-4” fullranger as mid/tweet to control dispersion on a bookshelf build which will be placed in corners. I really like the looks of the 10F on paper and in bikinpunks measurements but the Tang bamboos are half the price and the reviews are shining. Upper sparkle isn’t a priority while a smooth off axis response is otherwise I’d go with the RS100. The Marks are also on my radar. I’m limiting my choices to drivers with perfect circle frames aka no fatal drivers with those screw holes that stick out or the many full range drivers with the square-ish frames. 90db maximum is desired with a crossover anywhere around 200-600 hp. What do y’all think?
