For all the those who say this is not a SMPS...read this
http://www.diyaudio.com/forums/power-supplies/187973-1000w-smps-based-ir2110-4.html
Maybe you will learn something.
Well I have This core available. Wondering if I can use it for SMPS. I cant find out material in datasheet too.
If I am correct, that's an ETD39 in the data sheets?
with ETD39 you may get 700W.
Some manufacturer's of classd audio amps and other's use a similar smps PWM @ about
50% duty cycle and no output inductor(no regulation).Most are HB design offline..
Ltspice is free spice simulation software aimed at power supply design and with it you can simulate this schematic and get an idea of the pitfalls of the design.
hello dear friend
my name is Hadi from iran
i want to creat my own car amplifier but can not to creat smps for that.
i see in diy site you do that in past.
can you please help me to creat a good smps?
sory for my bad english
my email adress is Hadi_ghr_e_61@hotmail.com
very thanks for your helping.
have a nise day dear friend.
Hello Hadi,
just for reference, you can check out
Switchmode Power Supply For Car Audio,
it is a good starting point for DIY car SMPS, well explained...
Hello Hadi,
thanks
The construction of the transformer is very important, if using an ETD type core set the primary current might require you to gap the core if not it will saturate quickly and result in the mosfet's overheating and fail.The rest of the design is a straight forward DC-DC converter design.
Hypex are using the Gapped Core trick
SMPS designers refer to this topology as a "dc transformer". its NOT a buck-derived converter, which is why there is no output inductor. startup is an absolute nightmare for this topology, but it does have the advantage of operating open-loop. there is a reason why buck derived converters have an inductor....
If one winds a really good transformer, has a top-notch layout (hint: this one isnt, but its a lot better than some of the commercial versions I've seen) and wicked low ESR output caps, the topologies inherent problems get much worse. I think the real advantage of this topology is that it works better when done badly. high leakage winding, planty of loop inductance in the secondary layout and a soft-start on the primary will give a circuit that actually works.
Hi
For 220V input AC can I modify input turns to 22-0-22 without any other modifications. This is a very nice design which I was looking for a long time.
Kindly help.
Sony Soman
New Delhi
Kindly help.
Sony Soman
New Delhi
- Power Supplies
- 1000W SMPS Based on IR2110
