1" throat CDs comparison
here is.... FWIW
The BMS 4526HE-8 measurement was not included. It shown for size comparison sorry!
The amplifier output level was unchanged across.
it's about 12" from the horn mouth.
On axis "eyeballing" sorry.
Raw data.
The Faital and BMS were bought used, all others new
  • CDs Comparison.mdat
    CDs Comparison.mdat
I time gated the results at 7mS. Something seems wrong with the PSD2013-8. The smoothest response is from the DE250-8, BMS4550 and Tymphany DFM-2535R00-8. The smallest BMS seems to be missing from the results? the level is too low to get any harmonic distortion data.
There is imperfect at the horn CD entry would its caused problem?
Any problem the "quantum phase alignment notch" caused should affect the response of all the drivers tested on it.
If it had much effect, there would be a similar peak or dip evident in the very high frequency response of all the drivers, but nothing stands out suggesting a common problem up high, though the horn's "ripple" response is evident up to around 3kHz.
