1 cycle broadband pulse signal with pink spectrum audio file
Hi everybody,
I'm looking for someone who can program/write a pulse signal spanning from 30 Hz to 18 kHz with a pink spectrum. Each frequency needs to be 1 cycle long and all frequencies need to start at the exact same time. The peak level of the of the complete signal should not exceed -3 dBFS at 24 bit 48 kHz. Preferably WAV file.
If you know of an existing file or source that approximates these parameters, safe yourself the work and point me in the right direction.
Your help is greatly appreciated!!!
Sincerely,
Merlijn van Veen
