1.4” to 2” adapter Eighteensound
I am aware of that.
Problem is that Toutepaleur writes that it fits drivers, atarting with ND, but they do not mention the NSD drivers.
I just fear that i.e. exit angle is different.
Somewhere, I read that exit angle for NSD1480N is 10 degrees, but it seems impossible to find the exit angle for the ND1460/1480.
I am aware of that.
It fits, there is no critical dimensional difference between a ND1480 and a NSD1480, the extrenal dimensions, front face, mounting holes and throat/ exit angles are identical.
And you will basically have a NSD2080 , which Eighteensound does not sell from the factory 🙂
The ND2080 is a 1480 with the adapter.
It also fits the 1460 series, with "lower quality" magnets making the ND2060.
And the one below, fits all the ND3's.
https://en.toutlehautparleur.com/adaptor-for-compression-driver-1-4-inch-to-2-0-inch-for-nd3st.html
Eighteensound just conformed that it work, however, I need the version ending on 00000, not 00004.
Yes i am aware, i did not include the link to the 00000, as you already found it in your first post.
As i wrote above the 00004 fits all the ND3 range🙂
For whoever searches in the future wanting to make a 2" ND3N or similar.
It's also listed to fit the ND3ST and not the rest of them. Sorry for any confusion.
