0-speakers in 67 minutes
noodle_snacks said:
That looks like one of the jaycar carbon fibre drivers.. I am interested in which one it was, and what box volumes they are etc...
Its the 6.5" carbon fibre one, Specifications:
- Nom impedance: 4ohms
- Power handling: 80watts rms
- Freq range: 43Hz - 5500Hz
- Sensitivity: 89dB 1watt 1metre
- Voice Coil Resistance (Re): 3.79ohm
- Resonant frequency (fs): 43Hz
- Mechanical Q factor (Qms): 9.758
- Electrical Q factor (Qes):0.471
- Total Q factor (Qts): 0.449 ]
- Equivalent Volume (Vas): 15.1Lt
- Cone Area (square meter): 0.0133
- Mounting Depth: 75mm
and I have just made the 2 cabinets as suggested by jaycar:
Vented Box
- Box volume (litres)- 21 Lt
- Tuning Freq (Hz)- 44 Hz
- -3db Freq (Hz)- 40 Hz
- Two Vent Options
- Vent dia 50mm / Vent length 113.5mm
- Vent dia 66mm / Vent length 204mm
- Inside Cabinet Size: 225Wx282Dx350Hmm
Sealed Box
- Box Vol - 10.6 Lt
- Tuning Freq - 73.4Hz
- -3db Freq (Hz)- 74Hz
- Qtc - 0.707
- Inside Cabinet Dim: 175W x 220D x 277Hmm
I will report back with results. You'd think that since jaycar is throughout Australia and NZ it would be easier to find feedback on their speakers:xeye:
I'm doing a similar thing myself with some audax drivers, just for sealed (i don't want any resonances in my speaker enclosures that are not under direct control of the amp - like a port) though. my idea was to make one box of the larger size and fill it with bricks for tests on lower volumes, although this does mean for the smaller vol, i will have drifted from the "Golden-ratio internal dimensions for speaker enclosures". This does not bother me as i hope to not be using parallel sides and will concentrate on achieving a the lowest possible frontal area, which will take me away from the "golden-ratio" anyway.
Well I think they sound pretty good. They show how crap my car stereo must be because I can hear new things in familiar tracks.
I dont have much to compare them to though:xeye:
The vented one, which is tuned to 44hz makes more deep bass than the sealed one - which I guess was predictable but there is a difference in the mid-range, not sure what. I think the vented one has more defined mid-range.
They are both quite different but I still cant decide what one is better:mad:
Just to point out it is EXTREMELY dangerous to store propane (LP Gas) in an enclosed space.
Propane is heavier than air so it tends to travel across floors and usually finds sources of ignition such as a furnace or water heater and the resulting explosion can be rather nasty.
Also, and potentially more dangerous is propane displaces oxygen so if you were to inhale some it can possibly displace the oxygen in your lungs and once it does you can breath all you want but the propane won't go anywhere so you suffocate, it is of course possible to hang upside down long enough for oxygen to displace the propane but by that time you are usually dead.
I say these things because I care about my fellow DIY'ers and I happened to notice the LP Gas tank tucked under the left hand side of your bench and depending on how full it is and the ambient temperature these tanks are designed to vent LP Gas or worse yet if some sort of accident in your shop should cause the valve or tank to rupture the subsequend burns from the LP Gas escaping could injure you just from contact (very cold).
So please even if this is apparently an empty container (LP Gas tanks are never empty unless they have never been filled) move it to a storage spot outside, the life you save may be your own.
OH and P.S. don't store LP Gas near where pets may frequent as the gas is more likely to kill them than you.
Thanks and sorry for the rant.:smash:
Thanks for the advice! ;) It has actually been refilled and put back to where it lives now (which is in a little cage outside the house).
Mark25 said:
Max,
it's not the same driver, but bear this thread in mind:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=37953
Your car radio may not have the bass deffinition to make the effect mentioned in the thread noticable.
Mark
Hmmmm.....What is "group delay" in laymans terms?
I just put these two inclosures into WinISD and I see the group delay graph is quite different between the two but I am not sure what it means :whazzat:
as frequency falls, the phase of the drivers output changes, meaning some F's will be at different phase to others. the effect is exagerated with reflex loading. for 41Hz, 4mS delay for closed, 10 mS for reflex. although some say you can't hear less than 30mS delay, so it doesn't matter anyway.
After alot of testing with my PC hooked up to my Amp I am definetly going with the vented one.
I got my wood today, 18mm MDF.
I have 2 questions:
Will I need to brace my cabinet front-back and left-right? (It will be just like the larger one above)
Is speaker linning/damping meterial good for vented enclosures?
If so, should I use the fluffy sort of linning (650gsm) or the tar-like stuff?
Edit: Also, do you add volume to the enclosure to compensate for the linning/damping?
Bandpass or bust.
Hey! Those drivers tune up nice in a 2-port 6th order bandpass box. Look what you get for just a 1dB sacrifice in efficiency. Modest size too.
My cabinets are almost done:)
I got my tweeters today. Vifa D26 TF 05-06:
But I cant find any info about them except for this one site:
http://www.kochaudio.de/vifachassish.html
I cant find anything in google apart from ebay auctions from one guy and he copied the specs from the above site. I have emailed DST a week ago but no reply. Does anyone know where you could find reliable specs for this driver? (I have searched this forum too)
