Hello everybody!!🙂
I wanted to make the electra amator loudspeakers, by Sonus Faber..
Is anybody have the original designs for the wood enclosure & the crossover circuits?
I would like to build a clone from wood 😉 !
I don't know if i can make it but i'll give it a try!!!
Thanx a lot!!!😀
Thanx a lot!!!😀
No designs, but wouldnt be too hard to make.
Scanspeak 8545? Seas 10mm tweeter?
Stereophile has review & measurements.
Thanx Ap!
I found in the forum the crossover, i'll search Stereophile for the enclosure..
Any other sugestion for DIY project in this kind of speakers?
My uncle a lot of years ago had bult the BBC LS3/5A with KEF B110/T27!🙂
They where preaty cool!!😱
I think that i want a little more responce down there...
Electa Amator : Audio Technology (custom SF) 18cm
Dynaudio Esotar
Electa Amator 2 : ScanSpeak 18W + passive rear
ScanSpeak 3/4"
Inertial
Dynaudio Esotar
ScanSpeak 3/4"
Inertial
That would be the Scanspeak 18w8545 for midbass &
If the tweeter is a Scanspeak, then it has to be the D2008/8512.
For the box an easy trick to do, is make a regular box out of MDF & then glue hardwood panels on to the top/bottom & sides.
http://hififorum.knaak.dk/zalve/slask/mattias/images/IMG_8202.jpg
Thanx!! 🙂
Anybody have a better suggestion than the Electra Amator ??
I intend to build the Leach Amp, my Preamp is ready (with AN5534 - AN5532..)
I wanted for beginning that kind of speakers..(First time DIY 🙄 !!)
Thanx
Thanx
sonus faber
Hi from greece
The electa Amator (YEAR 1988)
DYNAUDIO MW-180SF Woofer (Hard to find)
ESOTAR 330D Tweeter
I have the crossover Sschematic
but without values
Hi from greece
ESOTAR 330D Tweeter
but without values
perdone me stavros,
the woofer was an AUDIO TECHNOLOGY ( SKAANING) not DYNAUDIO.
Inertial
Inertial
Do anybody have the cut-out drawings for the enclosure?
I've got the crossover network schematic. I'll check it out with the drivers, but i think they are from Dynaudio..🙄
http://www.stereophile.com/loudspeakerreviews/874/index.html
SONUS FABER
I think Inetrial has allright
the woofer seems audio technology
Today similar to MW-180SF perhaps SK-170 (500 $)
Afternoon i'try to find for you the dimensions and any
information.
But please tell us the crosover values
stavros
information.
stavros
Correct the original Electa Amator (Extrema?) used an Audio Technology Flex Unit woofer- most likely custom specs, he will make any drive to your spec. The second series used Scanspeak drivers. The original would be far more expensive to make, but the xover is probably going to be easier, whereas the series two would be cheaper although xover much harder - take your pick!
This is the crossover of the original Electra Amator I !!
I didn't remember the site which i found it but i'll try to get it again..
sonus faber
I agree
the electa amator crossover is very simple
1. wf --> one series inductor for woofer
2. Tw --> one cap in series with RC and R parallel to Tw
all in phase
bass reflex
Fb=40 Hz measured
and Fcross about 2,2 Khz
external dimensions H=370 W=220 Depth=350 mm
white afroacrylic 40 mm left,right and back
stavros
I agree
all in phase
bass reflex
Fb=40 Hz measured
stavros
The x-over was epoxy-sealed, unfortunately.
Anyway a true clone I think it cost much more of a good pair SF used,
in this particular case!! 🙁
Inertial
Inertial
Pardon me to dig-out this thread .
Any idea of the tweeter used in SF Signum ? Is it the same as the Electa Amator 1 tweeter ???
hello
Electa amator 1 and 2 crossover and box seeking, in addition to published in any drawing, picture, information.
Amator1
MV180SF
Dynaudio Esotar T330
Amator2
Scan Speak 18W8545 (18WSF1)
Scan-Speak D2008/8512
Sorry, Google translator
Amator1
MV180SF
Amator2
The tweeter in the Signum is a custom front plate Vifa TC20TD 3/4" textile dome, WITHOUT the ferrofluid.
- Sonus Faber Electra Amator DIY?
