Dayton RS225 TML
Hi guys,
I recently got a pair of Fostex H400 horns.
They were in bad condition.
So I decided to make them pretty again and use them with a pair of Beyma CD11Nd or CP385Nd which I have at hand.
This is what came out
For the moment I paired them with my PPD Subs. Just to hear what the horns are capable of.
The PPD subs are supposed to play up to 300-400hz. So this is by far no perfect match crossed at 1k.
But I really like what I hear from the horns
Reactions: 6thplanet
I have a pair of RS225-8 laying around. So I stumbled into the thrad '10F+RS225 FAST' and decided at last (after some advice from XRK) to build a pair of tml enclosures for the Daytons.
The enclosures are to tall for my taste when I want to put the horns on top.
I am aiming for outer Dimensions of roughly 40x30x75 cm
So with 5cm Granite bases the center of the mid/hights horn will be 90cm from ground.
I unfolded XRKs tmls to evaluate the geometrics.
The tml is about 95inch (241cm) long.
Cross section starts at 68sq inches (438cm²) and ends at 2.25 sq inches (137cm²). The cross section tappers very evenly across the length.
So how to fold the TML into my preferred enclosure dimensions?
Reactions: xrk971
The difficulty is to fold it to the enclosure dimensions with driver on the upper half and the opening at the front.
So here are some attempts which are more or less having the desired geometry.
All my attemts are bases on an inner width of 25cm.
This one is 250cm long with an opening of 142cm² starting at 400cm².
The next one is more complex to build because of the no 90°angles.
This is 230cm long ending in 125cm²
This is a short one
190 long, 142cm² mouth
All these simulate in hornresp very similar.
The shorter one need some more stuffing to get the response more even.
At the end I think it makes not a big difference.
I will cross the tml at 1k-1.2 k to the horns actively with minidsp.
This is interesting. I’ve been thinking about an 8” or 10” driver in a transmission line for bass use under some front horns.
No RS225-8 on hand…They are cheap enough to get a pair.
I have a variety of 8” like some B&C 8pe21 and Fostex 208ez etc
I wish I could wrap my head around hornresp better and design something like this.
Do you have any internal dimensions?
Nice work…….but with the low Fs of the 225s and their damped construction, I don’t see any need for a horn application in this case.
I would get two more though and wire them in parallel per side with a .5 inductor in line with the bottom woofer to combat baffle step and eliminate lobing to the horn. Will blow the doors off your horn solution in resolution, distortion and midbass impact.
Never saw that one before…
Bump for the OP…and some feedback from you experienced TL guys.
OP is trying to do something with a currently available driver with good usable dimensions that I would be interested in…and the driver is not too expensive.
Reactions: Jazzfan
Actually, yesterday while writing I was thinking of the old triangular base TL design around the B139 woofer.
That would be a good match with the horn!
page 215 A.R Bailey
https://www.worldradiohistory.com/UK/Wireless-World/70s/Wireless-World-1972-05.pdf
similar ? VSonics TL-AKSA
(Modeling ?)
https://web.archive.org/web/20110926081449/http://www.aksaonline.com/products/products_Vsonics.html
https://www.audiocircle.com/index.php?action=gallery;area=browse;album=2123
https://www.audiocircle.com/index.php?topic=70732.0
VSonics woofer​
SEAS CA22RNY/H1471 Prestige Series 8" handcoated paper cone​
vas 82 litres
qms 1.69
qes .36
qts .30
https://www.madisoundspeakerstore.com/approx-8-woofers/seas-h1471-ca22rny-8-paper-cone-woofer/
Dayton RS225-8
vas 57 litres
qms 1.46
qes .51
qts.38
https://www.daytonaudio.com/images/resources/295-356--rs225-8-spec-sheet.pdf
post#31
https://www.diyaudio.com/community/...-aksa-the-saksa-85.294346/page-2#post-4790530
other TL
old 1995
OA-Transient II-Ronald Koot from SpeakerBuuilding.com
Scan-Speak 18W/8542-05 Vifa D27TG-35-06
https://web.archive.org/web/20101129145208/http://speakerbuilding.com/content/1033/
small Troels Scoperta
http://www.troelsgravesen.dk/W15LY001_HDS.htm
