Hello diyers,
I've been playing sub-less for few months but with time I realised I was really missing a clean first octave.
My boxes are not able to go very low, it's 2x 15OB350 per side in around 200 L.
They can go low with EQ of course, but they just sound better crossed around 35/30hz, lower is just noise.
Don't know if it's the drivers high fs/qts, the "still" too small boxes or maybe not strong enough, or the room placement, probably all combined.
I see them more as big mid-bass in fact.
I had in mind to upgrade the drivers at one point, for the nero-15sw800 that should better fit the needs, but even if they're not that expensive it's still four of them that I'd need. And more important I'm not 100% convinced it will be a big improvement due to the mains placement.
So before going there I have to try spread bass again, within following constrains:
1 - nice look and integration with furnitures
2 - high sensitivity
3 - critical damping if possible
#2 means big drivers, I still have my four 18sw450 from my previous dipole, why not using them?
#2 and 3 kind of go together, but against #1 for the size implied.
#3 is a way to finally decide for myself if an L/T box can really sound the same as a big natural one (and I believe not, but lets' test).
I started with what I had around and within the new room layout constrains, with a sealed um12-22 in maybe 100-120 liters (much bigger in real but with sand walls) right behind me.
Not bad at all but not enough juice, plus it's not easy to nicely integrate with the furnitures.
I couldn't try my old concrete ported one as I got rid of it few months ago (and for that I had to destroy it in place, too heavy to get out 😛). I don't regret, it stayed for years unused in the same spot, it was fun to build, but also just too bulky, and too hard to move around to test different spots.
So, I had to find a way for 2-3 subs, placed behind me, light enough to move around a bit, but big enough to not require an L/T, easy?
Thought about it few months ans was about to buy woods when… again my favorite/hated shop just launched a new serie: the rådmansö.
Beautiful pieces in my mind, I would have loved to start with these when I've built my mains, a lot of cool stuff could be built around them.
Went to see them in real, and realised even the big one could do it, this one, 159x64x46cm, 468L. :
Got one, some mdf, some valchromat and let's go.
Like previous stuff I've just built a box within a box, 18mm glued all around inside, 24mm for the back, half the baffle doubled in valchromat, bracing with scraps, kind of light. The good surprise is that the radmanso is full particle boards, no honeycomb core on this like on many others, so nearly 4cm thick particles + mdf at the end.
The baffle is removable so I could add more bracing later if needed (I already found a spot that may need it).
And I could try 1 or 2 drivers, even clamshell isobaric if the box is still not big enough 😛
It's around 330-350 L. I'm guessing. Yes I did some sims but, they're just sims…
I of course did few mistakes again, my very first move was one! While sanding the inside of each panels for better glueing, I messed up and sanded the wrong spot of the panels, the edge that would have been visible outside. So I couldn't get the recessed baffle like I initially wanted.
Damn' what an idiot. So the baffle is now flushed, I'm sure it would have looked much better with the recess (like the mains).
Maybe I'll add a fabric grill, I'll see, it's fun to see the big driver too.
Then the valchromat was finished with tung oil, for a nice dark contrast.
Some details are left for later like the right cable, neutrik connector, better driver screws, replace temp wheels once in place to decouple a bit etc.
Not sure I’ll use the original steel stand that comes with it, it’s sturdy but will add 20cm in height.
I quickly plugged one little fosi on it yesterday and it seems promising, efficient for sure.
I hope I can move it in the right place soon to measure it.
Meaning right below the diffusors behind me, where I now have a bunch of besta used for storage.
In all this I kind of try to find the same effect I had in my car years ago. I might repeat myself but it was so fun with 2x15'' at few cm right behind the head. Breathtaking was the right word, literally, and I'm not talking SPL, just air movement in your lungs even at low levels, like someone with a pump trying to empty your lungs at every beat!
Of course home environment is a total animal but if I can get 10% of this I'd be happy 😛
Will come back with measurements soon, if a success I will build another one, and maybe even 3 in total.
Cheers!
Cheers!
Hi!
I'm just curious to understand your goals.
If you speakers are for indoor use and not for super high SPL, why do you limit your plans to have a high sensitivity speaker?
In general, they don't have a good bass extension.
According to your description, your first box had 200 liters with 2x15OB350.
In this configuration F3=44Hz and F6=41Hz. Too much space and material for not a good result.
For a pleasent bass response, F3 must be at least 30Hz.
With your new size, 350 liters sealed and just one 15OB350 speaker, things will get just a bit better: F3=43Hz and F6=33Hz.
Still, a lot of volume for just F3=43Hz
The option with your speakers would be a ported box which can be easily implemented in your project (just a round hole and a duct).
With 350 liters tuned at 25Hz and 1 x 15OB350, you can have F3=25Hz and F6=21Hz - This is really good!!
On the other hand, if you use a lower sensitive subwoofer SB26SFCL38-8 (10" / 88 dB SPL), less than EU100.00, for example, in a 350-liter box tuned at 19Hz you get F3=16.5Hz and F6=15Hz. This box would be something really special and with amazing listenting experience.
Hi Ron68!
I do like pro drivers yes, but I also enjoyed more typical sub when size was a constrain.
About the low extension they can often do just the same, their efficiency largely compensating their slope.
Plus they’re really happy to go higher if needed.
But I see that I wasn’t clear.
The 15OB350s are used in my actual main speakers (check the link at the beginning), I picked these at the time for their price and because I wanted to stay sealed.
Their response goes down to 30Hz naturally where they're placed, a bit lower with EQ but then don't sound right so low imho.
I also want to use multiple subs to manage some room modes.
One of the goal was also to re-use what I already have (that's 3xUM 12 and 4x18SW).
I could have used the 12s in small boxes like in a previous setup, but wanted to test the big ones.
So the new boxes are for sub only, will be placed in the back where I don't have size constrains, kind of nearfield (around 1m.).
And I don't want ported right now, I just prefer sealed, for the ease of integration with extension and delays, and sound preference, so far.
Now it's not a guarantee that it will work, all will depends of the integration, will have to keep the xo low, or play with a bit of overlap with the mains I'll see.
One last thing, I really enjoy for some reasons lowering the power needs, simpler and smaller amps, or even tubes.
Got down to 2w for mids and high, 100w for the woofers with low boost but much less without.
Based on the quick test yesterday I imagine the new subs to be happy with less than 100w too.
Started the integration yesterday.
Bit of a pain to remove all diffusors to place the sub, centered for now.
With two I will spread them apart a bit, symmetrically or not from MLP.
Anyway, nearfield and MLP sweeps:
I'm guessing the large dip between 50-70HZ comes from a mix of ceiling and front wall cancellation (2.7 and 5m.)
Should be manageable with 2 subs and a bit of EQ.
And I could try to add a bass trap on the ceiling right above me, already have a bunch of diffusors up there but really thin, mostly for the highs and the look.
I can only show these screenshots because for some reasons I can't save my REW files since few days!
So strange, the soft won't let me, not such a big deal because I don't really save anything anymore, just too many files and I usually don't reopen them anyway if I can finish in one session.
But now I need more time for these subs, I should try to reinstall it maybe.
Or maybe it's due to my recent mac update.
Also some DATS measurements, out and in the box:
I selected the driver with the lowest FS of the four, 28HZ when all 3 others were around 32Hz, similar Q for all, at 0.35.
The in-box sweeps shows a little messy impedance.
8 polyester cushions inside, it's a bit of a pain too to remove the baffle especially now in vertical position so I won't adjust that soon.
Only when the second box will be ready once I displace everything again.
Box Q is very low so I wonder if I could just add another driver in there, after all I have four, and then use the smaller box/dresser for the others…
Then started the XO work, ended up with 50Hz at 24db LR, acoustic.
Tried some overlap and it was not bad but I would need more time.
The sub has severe eq cut and I tried to minimise EQ use on the main woofers.
In fact I now don't EQ them at all and it sounds good.
Took the following screenshot during the process, these are not MLP sweeps, but nearfield to track the targets.
MLP sweeps were of course a lot messier:
I struggle a bit to define the time delay, I have to favor one side of the main, both can't sum perfectly at the same time.
it could be good for 90% of the tracks and then suddenly something will sound off or the sub will start to call attention on a few new tracks.
But it's on the right path I think, there's definitely some breath/chest effect.
Funny thing is that I seem to play everything at a lower level, maybe around -5db for a similar feeling.
Sub energy is so dense that the mains use now even less power (and of course for the woofers).
This is the honeymoon period, revisiting tracks is fun but I need to find the sweet spot between thump for electro and not distracting for jazz.
And I'm surprised that it doesn't rattle more, it’s only on 4 little wheels and on a concrete floor, but maybe the diffusors weight tames that.
But all this will be more clear once I can share measurements again!
Got my REW back!
It was something related to java and the dialog box/folder rights, had to use REW dialog boxes and not OS.
Surprisingly AI was very helpful here.
So to illustrate the issue I'm facing with the sub integration, here are few pics, I used RTA MMM too for once.
So one pt sweeps on top, rta at the bottom, house target off
I tagged what I did during the session, not visible yet:
RIGHT
LEFT
For now my issue is with the sub integration with the woofers.
Using tape measure the sub delay should be 6ms, and it sounded ok but I finally preferred 0ms, summing was not perfect on both but a compromise.
Rta left/right and both:
But playing with the REW alignment tool to get it perfect, it asks for 20ms on the left and 50ms on the right!
I'm very surprised by the amount of delay, but I never had GD in mind while doing this.
I usually just use distance + reversed polarity technique but maybe I was always off by few cycles in the past on all my systems!
Here's the sub GD, I don't know if I did it right here:
But I can see a large swing in delay between 50 and 60hz, right where I cross.
Maybe I should:
And here I'm trying all passes filters, here clearly I don't know what I'm doing.
Played a bit with the numbers in rew eq and predicted phase.
I had really no idea of what I should start with, but I can see that on the left woofer (LW) I can align it with RW with a low Q all pass at 50Hz.
Well if this is really what this graph means:
off/on
Or I can adjust the RW instead:
I still have to implement these to test, but during the process I tried a few numbers kind of randomly and it seemed to have an effect.
Sum was not perfect but it got better, now I have to understand of the all pass filter really work, to define the right frequency point and Q.
The really low Q of 0.3 I used should have a large impact on the entire bandpass right? is it too low a Q?
What I don't understand too is that with 0ms delay on the sub, I get these spectrogram, left than right:
in 1/6, pretty smooth, I can't see how adding 20ms would help here
in 1/24, oh wait, here are my 20ms swings!
It sounds no bad at all right now with 0ms, and I can keep it like that until I add another sub, no need to optimize yet.
But I need to understand so I'll be ready later.
Also one great lesson, check with RTA first! Even averaged sweeps are not that in line with the hearing.
PS: So cool, I just realised I could just copy/paste my entire post from the txt notes with all pictures embedded without having to upload them manually!
- sub: lot of eq needed like -15db cuts, little dip at 50Hz but kind of ok
- woofers: both suffer a dip at 90Hz but the left one has a severe one at 50Hz, can't figure out where it comes from
- mids: no eq but I realised they could use a low q cut at 1Khz, the house target might have masked this a bit
- horns: rta are pretty smooth, I have to not forget the sweeps are not representative, especially during future time alignment
RIGHT
Maybe I should:
- just pick a different XO point
- try an allpass filter on one of the woofer for phase to better match
off/on
- maybe I just don't use the right parameters in rew eq for the all pass?
- or I measure wrong and it's not representative?
To find out about the dip on left woofers, I did some test yesterday: door test.
The room has 3 doors on the front left corner.
2 left doors are for small storage spaces, and top one to the outside.
I had the habit to close both left doors for listening session, top one is often left opened to the garden.
The speaker is 2 m away of the corner, kind of like this, top is front wall:
+______
+ S
- wall
+ doors
S speaker
So I measured the left woofer with each door opened/closed and the combinations.
I expected the outdoor one to have the biggest impact but not, it’s middle one that really has an effect:
purple: all doors closed
orange: middle door opened
At least I know now!
+______
+ S
- wall
+ doors
S speaker
I just noticed that the cat was doing QC of the subwoofer 😀. Approved? 🙂
Nice job @grosso ! Congratulations... 😎 😎 😎
I have been tempted by a sealed subwoofer for the qualities of a sealed enclosure in the bass : always tighter than a BR, but unfortunately in need of large volumes (like you do) to have a suitable deep bass response. It was not applicable in my small dedicated Auditorium... Yes, unlike in yours, the space is very counted here !
Then I discovered and experimented the Ripole subwoofer, as invented by Mr Axel Ridtalher, a German acoustic engineer : it was THE solution to my needs... I ended with this personal design, my Omega Ripole :
This is a slight variant from the original Ripole : the internal panels are slanted to allow the subwoofer module integration, while meeting the required ports sections.
The plus : with only 2x12" and 400x400x440mm, the results are simply amazing... An infra-bass extension down to 16Hz, an unobtrusive, deep, floating wide, low-end ambient, a well-damped, tight response as found on sealed enclosures, no room modes excitation due to the front-rear ports arrangement. Moreover, the difficult association with Magneplanars (and possibly Open Baffles) is perfect, just to complete naturally their bass cut-off.
The drawbacks though : rather unefficient (think -6 to -10dB under the nominal efficiency of the speaker, depending on the configuration), not suitable for use over 60-80Hz because of upper narrow peak chamber resonance located between 200-400Hz typically (I cut mine at 40Hz @12dB/Oct. or ]@24dB/Oct. depending on speaker), and if you want to go for those loud Home Theater Boom-Crash effects, choose 18" speakers, well... For that, a BR Boom Box is IMHO more suitable.
To sum up, it was the convenient alternative to the sealed subwoofer qualities, when room space imposes compactness... Not allowing the benefints of a large sealed Sub !
T
T
My HT sub has two Dayton 15" yach in 360liter sealed. Only problem is bad position in the room, separate subs would smooth modes...
Unfiltered nearfield response
Hi, I'm planning a big subwoofer for my rather small home theater room. The room is 2,6x3,65x2,5m (9,5 m2) with low RT60. I watch movies and listen to music with moderae volume, so my main goal is to get fast and precise bass. The main speakers are concentrics in closed cabinets and they go linearly down to 60Hz, the sub,s xo is 80Hz and I use a Hypex DS plate amp.
The idea is to make a 400-450L closed cabinet for two 15" elements. The cabinet must have the form of a closed bench and it will sit below the screen right next to the wall and from corner to corner.
The elements could be...
- Juhazi
- Forum: Subwoofers
Have you considered PA drivers? 18" in 55l and more power handling than you'll ever need at home. Tons of EQ and power required!
MrKlinky, they are PA drivers, well if the label is important they're from SB Audience.
But they have an unusual low FS for PA, and are dirt cheap.
I had 12" and 15" regular sub in small boxes before, with a lot of EQ they worked, and of course needed much more power like 500w.
But since I have the room now I wanted to test a lower Q, to put a final end to this question (here I went so low I could add another 😛).
Merci tubelectron, I sure followed your thread with the ripole, lovely!Nice job @grosso ! Congratulations... 😎 😎 😎
T
I never tried ripole but had H-frames with my dipole (previous setup).
I absolutely loved the result, cleeaaan bass once most of the room is removed.
They were not working well with the new sealed mains.
And in the new room layout, allowed by the sealed, they would not be very practical, I love the empty space in front of me now.
But I keep ripole in mind for the future, one day I’ll try.
As I also want to try Infinite Baffle in house (after great result in car).
I have a sort of opening that I could leverage maybe, it’s a « saloir en pierre » where they used to store meat in the salt, I guess a stone salt cellar in english.
Pics when I arrived in the house:
It would be shame to not restore and hide it, but I can’t stop thinking about it, I’m sick 😛
- Juhazi
- Forum: Subwoofers
Wow 360L in 10m2! More insane, so do you keep using them? I see that you measured them recently.
Mine is centered for now and it’s not the best place for sure, but the dips are not that bad by ear.
I wonder if I should build 1 or 2 more, either another one the same size, or 2 slightly smaller so they could be more optimally placed.
It’s mostly cut and xo to shape it, with a little boost below 28Hz, near-field:
Amp is a little fosi v3 on 32v, and based on the impedance reading it should push around 20-30w at max.
I need to measure the voltage to see where it is at regular level, probably not much because it stays cool.
But adding one can't hurt, if only for the smoothing.
Still there, but not much use because kids have moved away. Volume is 235 liter x2. The aim was to go low with low distortion, not max spl. But for sure they can make the furniture shake, rattle and roll...
I like LR2 around 80Hz best, lower group delay. Measuring for xo is difficult because of room modes and long gating required for 40-120Hz. I finally put a main speaker right next to subwoofer and measured them at about 30cm.
Yes I did try to overlap at the beginning, treating them like 2 subs but didn't get it right.
Mains are not that happy below 30Hz and it felt fuller but less precise, but maybe I just didn't spend enough time on it, it’s still on the list.
Also tried shallow slopes on both but the sub is very nervous and I could still hear it above 200Hz (it’s very close to me).
Whatever I do I think I need to first fix the phase discrepancy between L&R at 50Hz.
I want to try the wavelet method used here (video posted on ASR https://www.prosoundtraining.com/2025/03/21/mains-sub-alignment-a-different-take/) Very clear to illustrate what is going on there.
Once fixed I should be able to compare all methods.
- Subwoofers
- Big sub sealed
