QUAD 2 Problems
Hi, I'm restoring a couple of Quad 2 monoblocks. The amps worked a long time ago and I have replaced all the rsistors with Kiwames, the main psu caps with F and T 15 + 15uf caps and the other electrolytics with decent quality Nichicons. Coupling caps have also been replaced. On turning on the amps the rectifier and output tubes all flash as if the amp is oscillating wildly. The cathode resistor (5 watt) is getting very hot quickly so the tubes are dissipating much more than they should. Both monoblocks are behaving identically so it cannot be a case of a poor /missed connection. I tried adding two x 22pf caps to the grids of the output tubes which made no difference. So my questions are:
1. Any pointers on the cause given these amps are generally stable?
2. Any pointers on the best way to test given I don't want to have the amp operating with this level of excess dissipation?
Thanks in advance
David
What you describe is usually caused by leakage of the two big coupling caps - but you replaced them. To be sure check power tube grids are at zero volts all the time before you switch off. Are the big tubes still good ? This thread is missing pictures.
Are you sure, that gnfb correctly installed?
Is the output snubber (4R7-390nF) installed, and it's in the right place?
Try amp without (removed) coupling capacitors.
Which version is this QuadII?
I havn't touched the gnfb so no reason to think it's incorrect (if as conveyed to me the amps worked previously). There's no output snubber on this version (version 2 I believe). Trying without the coupling caps is a good idea!
What is your mains supply voltage?
Maybe the amps were set at 220V or lower. Where does the HT settle at, at switch on?
Also have you verified how the earth is configured? Is the chassis earthed?
A long time ago one of my amps motorboated very badly due to a poor chassis earth.
I think the cathode resistors will run hot as 5 watts dissipation is maybe too small.
With modern resistor's being so small, even for 5 watt dissipation they do seem to run hot.
Hi, my mains is quite high-246v but the amps are set on 240v. HT was correct around 340 but of course fluctuates with the pulsing. I have implemented an earth lift system with the chassis correctly safety earthed. the correct dissipation for the cathode resistor is 3watts, which I agree would be reasonably hot, so 5 watts should be OK, not the enamel roasting I'm currently getting!
No mods apart from the earth lift for safety /hum reasons. Many have implemented this arrangement without issue and there's no reason for it to cause these symptoms. Anyway its the easiest thing to short it out leaving an earthed chassis
