Opinions on Vandersteen's posts and canopy
This is a random pic of a pair of Vandersteen, model 2, from the web. Of course, Vandersteen is iconic and earned it. We are not challenging the design, just curious: What's the purpose of the posts, canopy, and sleeves? Aesthetic or acoustic? What's your take? Also, what's you opinions on these speakers?
I think this is a clever solution: the 'hard' box is not visible so it can have a shape optimized for acoustics. A complex shape that only needs basic finish.
The external 'box' is acoustically transparent and is optimized for looks. A simple shape with 'good' finish.
Due to easier finish (fabric wrap) and highly optmize-able box shape this can be a good solution for DIY.
This was one way to reduce costs to the end user eliminating expensive wood veneer
and the same time the smaller baffle area was found to benefit time alignment
and sound transparency .
Richard regards any baffle area as added distortion coming off the drivers and the small
dimensions aid in a more rigid enclosure overall.
He made a concentrated effort to reduce end user costs without compromising superb
driver impulse response
The most difficult part of loudspeaker design is the aesthetics.
Yes. If aesthetics are not a priority, it is relatively easy to design/build a high performance cabinet. But if it has to be good looking as well... well, that is a more difficult challenge...
The 2c was a good speaker in its day, and it competed with speakers selling for much higher prices. Mr. V kept his prices down by keeping the aesthetics and finish work simple... as @AVWERK and @AlmaAtaKZ mentioned...
Vandersteen uses 1st order filters on most of their designs. I met Richard at a stereophile show in NYC around 2000. I tried picking his brain about the newer models he came out with at the time, but he was as tight as a clam when I inquired about the actual crossover topology. The 2ce was an excellent speaker in terms of resolution and detail, very good at playing classical, acoustic and piano music. They weren't that capable of any noteworthy SPL being a 3way, mainly thanks to the 1st order filters. The drivers were Vifa / ScanSpeak. The mid was very similar to the P17WJ-00-08.
