The FED16BT is used in the SA80 so it's possible it's used in the 120. Someone may have more definitive information.
FED16 isn't a complete part number.
The replacement is/was the FEP16BTD. The B is the voltage. The last letter indicates doubler. I don't see any available. With the extra rectifier locations available, you may be able to use something like the MUR820 and hard wire some of the terminals to make the equivalent. You could do the same with the MUR1620CT or MUR1620CTR.
The nomenclature/part numbering system changed.
The originals were:
FEN: negative CT
FEP: positive CT
FED: doubler
Then all became FEP and the type moved to a suffix, where needed. The A suffix is a common anode (negative). The D suffix, the doubler.
The originals were:
FEN: negative CT
FEP: positive CT
FED: doubler
For future reference, high voltage rectifiers (and virtually other component) has a greater loss than their low-voltage versions. This isn't a problem here but just because the voltage is higher, that doesn't make it better.
That said, here, 4 TO-220 packages will better dissipate heat than the originals.
- General Interest
- Car Audio
- Soundstream SA 120
