Triode - pentode switch conversion for Citation II amp
I need a schematic of how to convert a Harmon Kardon Citation II amp from triode top pentode mode.
Right now I have a 270 ohm resistor going from pin 4 of a Kt88 tube to 2nd & 4th connections on output transformer.
What do i need to change?
270 Ohm from screen pin 4, to Ultra Linear Tap = Ultra Linear mode
270 Ohm from screen pin 4, to plate pin 3 = Triode Wired Beam Power mode
270 Ohm from screen pin 4, to output transformer center tap (B+) = Beam Power Mode (A KT88 is a Kinkless Tetrode, which is a Beam Power tube, with beam formers).
A true Pentode, has a Suppressor grid, g3. A true pentode does Not have beam formers.
Pentode refers to 5 elements, but real pentodes had suppressor grids.
The pentode patent, forced RCA to come up with Beam Formers, to circumvent the Pentode patent.
Elements Pentode: Elements Beam Power
filament and cathode filament and cathode
control grid, g1 control grid g1
screen grid, g2 screen grid, g2
suppressor grid, g3 beam formers
plate plate
EL34 KT77
EL34 specifications = KT77 specifications. These are real good candidates for Tube Rolling
Reactions: gerrittube
My attempt at adding a switch to change states from Triode to Ultra.
Note switch is a dpst in the Triode position with RL1 closed.
Any comments are welcomed.
