PCB for LM3886/LM3876/ LM4880 in INDIA
The PCB -It will not be readily available.
U will have to make one for urself.
If u can laser print on a glossy photo paper then read here.
http://www.fullnet.com/u/tomg/gooteepc.htm
Other method is the good old one.
Draw the artwork using enamel paint on the copper and itch using ferric chloride. In this case go for 3886 as it's easy.
Want pcb layout, there will be hundreds in DIYAUDiO. I have one single sided design here.
Make urself one of this or make more and we will buy if it's good.
Gajanan Phadte
3886 and 4780 pcb made on order in india
hi fellows , i actually made DIY 4780 and 3886 pcbs. Here is the pics. If you are interested i can supply a few PCB on order.
Ya , i m from chennai, email id is kuldeep1@gmail.com
i have made 5 + 5 pcbs for my 4780 and 3886, made by laser toner transfer method. all are working excellent. If u wish i can mail u the pcb layout in pdf format so u can urself see. and i'll be charging Rs 200 for 4780 and Rs 100 for 3886 each PCB in case u are interested to buy it.
LM3886 & LM4780 in india
visit http://www.diyaudio.com/forums/showthread.php?s=&threadid=99176
I have made a couple of LM4780 and LM3886 PCBs by normal laser toner transfer method (at home) and i offer them for sale in india.
http://www.geocities.com/cool_mechi/lm4780.htm
and
http://www.geocities.com/cool_mechi/lm3886.htm
I will charge 350 Rs per LM4780 PCb and 250 Rs per LM3886 PCB.
Since PCB are home made, it will be in very native form (i.e only PCB with copper tracks, no component layout, numbering etc).
Interested persons may contact me.
LM3886 PCB for sale.
I am also willing to fabricate and sell LM3886 PCB in small numbers. The PCB will be glass epoxy type, Home made using toner transfer method .I have constructed a couple of amps using this design and it sounds exceptionally clean, no hum etc.:cloud9:.The design is 100% star ground based. PCB size is roughly 85mm x 60mm .Shall Take a few photos and post when i get time. I will be charging 350 per PCB. If interested contact me at i_am_007@rediffmail.com
oh okay, actually for reason unknown it is kept on getting delayed. I spoke to him 2 months back and when I checked last week, it was not ready.
If someone in Bangalore interested, we can get it done new compact design and fabrication. Its not very expensive. I am planning to do it but somehow time has been a factor.
I last week made subwoofer using chipamp and I am so encouraged with results that I plan to built few more amps.
PCB fabricators in Bangalore
Thought i shall post some details of PCB fabricators in Bangalore.
1) Prototech: 7 days delivery , 3 PCB min Accepts gerbers via mail. Phone no:08023570296
2) P.C process: 10 days delivery ,Accepts gerbers via mail. Phone no:08028362596
Both the above companies are trust worthy, have done many PCB's with them. Call them and ask them to mail you the standard pricing.
Hope this info will be useful.
Thanks.
