Dual triode power tubes?
I think I can use any of these. The Va(max) is limited so I probably will use an OT with lower transformation ratio.
Hammond should have 2.5k to 4/8/(maybe 16) at say 10 or more Watts that would need an increase in my mortgage.
It's an experimental design, sims says it works great!
Jan
I forgot about the 6BX7 and 6BL7. My first color TV, a 1957 vintage Emerson built by RCA used the 6BL7 for vertical oscillator and output. The two triodes are identical but one is intended for oscillator duty hence the 10 watt per plate, but 12 watts total rating. Mu is 10 or 15 depending on the tube type.
The 6AS7 has a Mu of 2 and most of the regulator triodes are also rather low. The 7236 is the same tube with a Mu of almost 5. There is another one, but I can't remember the number at the moment.
Then, at the other end of the regulator triode spectrum there are the 7241 and 7242 tubes. These are big (100 watt plates), hard to find and often expensive. Mu of 2.7 or 10 if I remember right. I have seen one, but never played with one. There are three independent triodes inside a common plate structure. All are wired in parallel. They are about the size of an 813.
