Navajo - 16 Watt Diamond with low distortion
Navajo
With Diamond Lateral MOSFET output stage.
THD 0.000044% at 1 Watt
16 Watt output with low distortion
First time I've seen a amplifier/electronic circuit named after a Native American tribe.
The Navajo (Dine) people live in the Four Corners area of the USA. It is the largest tribe in the USA.
Very good THD, but I would have expected more power output for an amplifier named after the biggest Native American tribe in the USA?
Reactions: hbtaudio
In a typical diamond buffer, U3,U4 compensate the temperature coefficient of U7 and U8. No bias generator needed. This only works well if all transistors are of same type BJT / MOS and thermally coupled.
Also, dependent on circuit details, a diamond buffer may swing closer to the rails than an emitter follower.
So in this case, what is gained? Lateral MOSFETs generally don't have issues with temperature stability. And the devices in the diamond are of different types.
Is it just the better efficiency by swinging closer to the rails?
Reactions: U102324
I tried this in LTspice and it seems pretty good 👍 but it does need an output inductor/Zobel to maintain stability (as do most designs). Small capacitive loads cause instability.
This is at 1 watt and 213ma bias current. The results agree very closely with @lineup
Might be worth looking at the slew rates. This is 20kHz.... and I think you have edited post #1 with different values on the diagram...
Giving:
Reactions: ZoltanChivay
Yes, I have changed. But only the the TMC capacitor values.
There are many native american tribes.
I have decided to name my amplifiers after them 🙂
Thanks for the work of @Mooly
Yes I should add Zobel at the output and a low pass filter at the input.
Reactions: Mooly
