ATH4 inspired mini monitor
1" compression driver ( 132 x 114 x 50 ath4 wg )
5" woofer
cabinet dims approx 165 wide x 270 high x 240 deep
here's the current model and vituixcad data
have you considered a wider (horizontal) pattern for the waveguide, like 120 degree?
great idea to go for a DiY 705p. apart from too low DI below 2k, this should be good enough for many. would also be interesting if active cardioid could be squeezed into the package.
Reactions: VoxCelestial
Wouldn’t take me long to narrow down on a wider pattern. Aiming for 5 watt ish for 96dB 60-20k.
“Budget CDs” and “Budget Woofers” so far …
1in BMS 4524
https://www.bmsspeakers.com/index.php-101.html?id=bms_4524
1in Sica CD 78 26 245
https://sica.it/prodotto/cd-78-26-245/
1in 18sound HD110
https://www.eighteensound.it/en/products/hf-driver/1-0/8/HD110
5in 18sound 5W430
https://www.eighteensound.it/en/products/lf-driver/5-0/8/5W430
Two passive radiators, SB or Peerless 830878. Looking for the best C/Q values. There are some inexpensive woofers that fit that bill too that could be modified to be PRs. Or cone debonded and moved to a new machined spider in the cabinet side walls.
High pass and 1 eq should allow 60Hz f3 with ample excursion to spare?
Still wide open to options!
When I was looking for 5" woofers I've settled on the Sica Z002655. Larger coil, Bl, Xmax spec seems more elaborate than usual. The surround is accordion style, it continues as a flat rubber ring over the frame as if it could serve as gasket for this type of mounting, but I don't have much experience with building stuff. It's not on their web site, would be nice if it's still in production.
Reactions: limacon
Hi limacon, looks good. Btw, anyone has good explanation why there is small undulations on the response increasing further off-axis? panel radiating sound making interference appear? period seems very short though, or random, so perhaps multiple things, like something in measurement jig turning with the speaker. or what?
Reactions: limacon
@tmuikku nothing yet.
Further refinements yeild positive results. Altering the chamfer angle/size using a custom box shape in ATH4 have yielded the following. A full radius/ellipcal shape might well be better but I like the chamfer approach to the cabinet.
Thankfully I can drop the baffle back on the machine and recut where needed.
I ended up with 15mm rounded edges and minor changes to the ath4 parameters.
Cabinet dims
Width 164mm
Height 280mm
Depth 280mm
Charts below created with
Code:
Mesh.AngularSegments = 120
Mesh.LengthSegments = 60
Mesh.ThroatResolution = 2.0 ; [mm]
Mesh.MouthResolution = 7.0 ; [mm]
Mesh.Quadrants = 14
Mesh.SubdomainSlices =
Mesh.CornerSegments = 5
Mesh.ZMapPoints = 0.3,0.2,0.7,0.9
Mesh.Enclosure = {
  Spacing = 16,16,16,150 ; edge distances (left,top,right,bottom) [mm]
  Depth = 280 ; enclosure depth [mm]
  EdgeRadius = 15 ;  edge treatment [mm]
  EdgeType = 1 ; 1=rounded, 2=chamfered
  FrontResolution = 7,7,7,7 ; front side mesh element size (q1,q2,q3,q4) [mm]
  BackResolution = 16,16,16,16 ; back side mesh element size (q1,q2,q3,q4) [mm]
ABEC.SimType = 2 ; boxed
ABEC.Abscissa = 2 ; 1=log | 2=linear
ABEC.f1 = 400 ; [Hz]
ABEC.f2 = 20000; [Hz]
ABEC.MeshFrequency = 1000
ABEC.NumFrequencies = 50
Reminds me of my cinema speakers, just in small:
A rounded Edge is still helpful.
But - how do you like the sound with such a steep rising directivity at around 2kHz? I once built a PA 3-way with 6" in the midrange and small horn for the tweeter. While the sound was very good (lot's of resolution for a time where 12" midrange was standard) I could not stand the directivity - very wide in the midrange but narrow for higher frequencies, didn't sound balanced or even in the room. That's probably a more extreme example as your build but it seems to have a similar tendency.
Reactions: Arthur Jackson
Update.
Cabinets recut with 15mm radus edges.
Measurements of each driver at 0, 7.5, 15, 22.5 ,30, 37.5 ,45, 60, 75, 90.
I've been listening today with parts I had in the drawer.
Some extra work do be done inside the cabinet to damp.
Reactions: DCDK
