This amp was not output.I see rail voltage on the outputs.The op-amps also have supply voltage.
I don’t see no oscillation on the output FETs.
Any suggestions?
Any suggestions?
If you drive a strong signal into it, do you see that audio on one of the rear pins of the BD driver board?
What's the DCV on pin 8 of the 5110 driver ICs?
Do you see oscillation on pins 2 and 4 of the 5110 driver ICs?
I see audio on three of the rear pins
5110 supply voltage 7.5v using main ground
There is no osicillation the pin 2 and 4
I was talking about getting audio on the BD card rear pins.
Voltage on the regulators are close to the ones on the picture.
Audio on 3 pins makes it look like there may be a problem with a ground. Which pis have audio?
Any pulses on Q200 or Q201?
Do you have a FLIR imager or freeze spray (canned air, component cooler)?
Is the driver board a BD or a BDCP?
The two make in red have audio but not as strong as pin 1.
No pulses on these transistors.
It’s a BD board.
I have a can electronic cleaner that I can invert.
It’s a BD board.
Freeze all of the ICs on the BD board and after they turn frosty, power up the amp while watching for components to defrost. Do any defrost really quickly?
- General Interest
- Car Audio
- T1500-BD
