Ortofon MCA10 Moving Coil pre amplifier clone
I have an original MCA10 that uses two 1.5V disposable batteries.
I rebuilt the PCB because I wanted to use a rechargeable 18650 lithium battery. After being fully charged, it can be used for a long time, possibly for a week.
Some changes have been made to the parameters of the capacitor, which seems to be better.
This is very simple. If you are interested, you can DIY it. A schematic diagram has been provided.
... Some changes have been made to the parameters of the capacitor, which seems to be better.
Nice job with the battery adaptation, but why did you add C5/C12 (22nF) at the output? It creates a severe high frequency filter, -6.5dB @ 20KHz.
If your intent was to reduce bandwidth, 22nF is excessive, eg: Red trace is with 22nF, Green trace is with 220p.
OTOH, C5/C12 are redundant. The same can be achieved simply by changing the value of C4/C10. Here are 3 values for C4/C10: 220p, 500p and 1nF.
Nice work. It's an interesting circuit, similar to the WM Leach design that was published in Audio as a DIY project way back. (Any oldsters remember that?)
Similar in that both are battery operated common-base, otherwise different topology.
I do remember the Leach, have built 2: a crude one way back in '88, another more recently (2018) and properly: The Leach moving coil pre-preamp
https://audiokarma.org/forums/index...g-coil-pre-preamp.838004/page-5#post-12415488
It's a simple and very effective design, still holds its own against the rest today.
You can throw out the large coupling caps and directly servo out the input offset - I did this on my X-Altra MC/MM to allow direct coupling of the MC cart. The common base configuration gives the lowest noise for MC inputs - Leach was way ahead of everybody else with this configuration. The X-Altra MC/MM achieves 232 pV rt/Hz input referred noise (measured).
Reactions: tomchr
感谢你做技术验证,22NF消减了高频,原始的MCA10在输入和输出的RCA连接器上都并联了22NF的电容器。这也是重建它的原因之一,重建的PCB适合任意修改,我附上一些原始的图片。
