Can i fit a two wire EU mains cable used as speaker cable into a 6.33mm male jack?
I'm rebuilding two very trashed Vermona L9033s and wondering if can i fit an EU mains cable into a 6.35mm jack like this? Thanks in advance.
This connector is not rated for mains voltage, so that would not be a good idea.
Not to mention that one of the conductors is connected to the bare metal handle.
And a stereo version would still not be a good idea.
If it's like the standard 3 conductor line cord like we have here in the US it probably won't fit...I was able in an "emergency" situation long ago to use some with a phone plug like that one by leaving the spring strain relief out and drilling out the cap end a little.
Mike
Then I'm puzzled, why do you not just find out which 2-core mains flexible cable in your collection will actually fit the plug?
Don't have the 6.35mm jacks yet and the local store doesn't provide any measurements of the connector sadly. I asked it if anybody did the same combination. Well i gotta use that 500m spool of mains wire somehow. Its my bad that i didn't clarify that i'm building speaker cables.
Reactions: Galu
