Getting back to my P3 after a lengthy hiatus, had a few SMD 0805 to do, working with new tweezers managed to lose 2
!!!! On the plus side the 2 that I did today are quite a bit better than the first 4.
Yes, 1000 would be more than a lifetime! The question really is, are these parts that are likely to be used in other designs?
BOMs are for Sissies
Every Sissie needs to make his own BOM, from schematic and parts placement printed in 100%
making BOM, from schematic and parts placement printed in 100% is for Sissies
Every Sissie needs to memorize the schematic and parts size and order each part individually from memory.
You lost some smd capacitors......I can find my entire Pearl 3 kit. Where did I put that thing.....?
If you're going to make an SMD P3 I would "heartily" suggest some 0805 ferrite beads on the gate of each '209
The government issue 7815/7915 are fine ... but you can do better.
I would never order anything from memory. I'm a check, recheck, triple check twice kind of builder.making BOM, from schematic and parts placement printed in 100% is for Sissies
No time for memory games in this for me, anyway! I'm like Homer S, learned how to make wine, and forgot how to drive.
- Pearl 3 SMD
