Rockford Fosgate Power 1000 mosFET
Pulled one of power 1000 out of storage to repair it. It currently has irf542 for the outputs and they are still offered at digikey. Does anyone recommend a different fet with higher current rating?
Hey Perry this amp came back and now it has rail voltage on the speaker output of one channel. Where can I find the drive signal on this amp. I have tested almost every component on the board for that channel and only found 2 resistors of of tolerance and replaced them.
I found this 2n5401 reading 148 ohms base to collector. Pulled it and it read the same. I replaced it now the amp pulls 5amps limited. I reduced the limiter to 2 amps.
I’m not sure if that 2n5401 is either of those in the pic
Good to check the numerous diodes.
Other components might have been damaged from the fly back voltages of the original fault.
DC offset would be assumed possible more failed mosfets.
Or if the frontend components failed. Since you found a bad transistor in the frontend.
Could be out of spec resistors or other bad transistors.
The bad transistor went bad or got too hot for a reason.
Even likely was taken out from fly back voltages as mentioned.
Might be helpful to show what transistor was replaced
and show/ post in the schematic
If typical current sources, if not functioning right there would be DC offset.
Not having full rail but partial rail, as a guess sounds like one or so bad outputs.
