Leakage current through the capacitors causes the voltage to appear across the speaker terminals. If there is a DC voltage across a speaker connected to the stage, then I would deem the coupling caps as bad, since that much leakage current is defectively excessive. Under no load conditions, then a DC voltage could well occur across the terminals, but the current causing it to appear would be minuscule, not enough to disturb a speaker.I am building the below amplifier. I have it done with the exception of hooking up a speaker. I measured from the point where the speaker connects to the cap and ground and I have 12vdc on my meter. Shouldn't the caps block the dc voltage? So why do I have 12 vdc there? View attachment 1289752
True.Not sure what the 10uF poly cap is for, don't think its needed in a coupling cap situation, just make sure the electrolytic has a high ripple-current rating and low ESR.
And even so, givent he unavoidable 15R source resistance, ESR importance pales a lot.
I've seen this schematic on the net for years, I've wanted to assemble it several times but never had the time or the real interest to do it, however I'm very curious to know how it sounds .
Yes. Me too...
T
The associated project to schematic in post #1 is this one:
https://diyaudioprojects.com/Solid/ZCA/ZCA.htm
and
https://www.diyaudio.com/community/...build-class-a-single-mosfet-amplifier.368606/
This is close to the ZV (ZEN variation, "Zen-lightenment" from Mr. Nelson Pass) from fig. 5 under
https://www.firstwatt.com/wp-content/uploads/2023/12/art_zv1.pdf
and this schematic under
https://web.archive.org/web/20031210152336/https://www.passdiy.com/projects/zenlite2.htm
check out also this threads:
https://www.diyaudio.com/community/threads/zen-enlightenment.53/
https://www.diyaudio.com/community/threads/2sj28-vfet-se-amplifier.154009/
Highest sonic performance is only guaranteed when using high-quality components (this is particularly important with electrolytics) and the use of a choke coil.
P.S.: The naming of the topic is completely confusing to me.
and
- Stupid question
