There are no references on the web, so what's wrong with this simple setup?
Hi, Please help me understand why people use SRPP, CCDA, cathode follower etc., while not using the attached configuration with two triodes in series and GNF.
This is also the one that when simulated gives me the lowest THD among all the previous ones that I have simulated, the one that has the most linear frequency response and also the highest input sensitivity.
(Let us use ECC83 only, pls)
You have lots of loop gain inside the FB loop, which explains the "good" properties, whilst a follower on its own has just the internal gain of the active device.
However, I suspect that your transformer has minimal parasitics in the sim. The reality would probably be less shiny, and stability issues could surface
I have seen plenty of schematics using a similar architecture for UL single ended pentodes, tetrodes etc. amps. It is not rare at all. But many tend to use very linear output triodes and no negative feedback. Some of those triodes are driven to A2 to get more power, requiring a more powerful driver.
And, imagine how boring would it be if everybody uses the same tried and tested circuit 🙂
The circuit is not good for what we want from tubes , especially from a single ended ... Huge gain open loop and a lot of negative feedback . Big possibility of oscillation or instability . Not good for hi-fi or guitar amplifiers either .
Strange is that you could think that such a simple circuit wasn't tested before ... of course can work but is not very desirable .
Thank you, but still looking for someone who anyway tested it. The fact that there is no reference, means it doesn't work (because oscillating) or work bad (bad sound). That's my only conclusion. The only reference I found was this, but the loop is on second tube and he uses a much lower gain triode. And simulating it gives much more higher THD than mine. But it doesn't explain why was not tested on the first stage and why not with the original 12AX7 (6N2P).
https://www.audiovalvole.it/amplifi...ng-a10/reisong_a10_audiovalvole_stage2_01.png
https://www.audiovalvole.it/amplificatore-valvolare-cinese-reisong-a10.html
The purpose of this amplifier is somewhat different, it is for testing heat-management:
https://www.diyaudio.com/community/...rging-a-e-pcl82-amplifier.351667/post-6134055
But it bears some similarities, except it is two-stages only. Yet, stability issues were not that straightforward.
You have three differentiating poles (2 caps and the transformer); avoiding motor-boating is probably possible, but it is not going to be easy
I'd worry that without compensation it could oscillate at RF. The acid test is building it for real.
It even (sim-)works. Nothing optimised, just put together the usual resistor/voltage values for a 12AX7 🙂
Here below I found a reference. Same scheme of ours simulated BUT WITHOUT feedback..... It is for a guitar, so it means non-hifi. And infact without GNF the sensitivity drops to 15mV at the expense of a huge THD.
https://miro.medium.com/v2/resize:fit:1100/format:webp/0*7O1yuvpRdPro_C4F.jpg
https://medium.com/audioxpress/you-can-diy-build-a-single-ended-guitar-tube-amplifier-40f23353dfb6
...and finally this is from 1958 : two ecc83 and one
It uses several loop of GNF and the OT is quite complicated (I cannot reporduce), but the overall concept should be directionally correct. The article says 0.3% THD at 9W!
It seems that you discovered America again 🙂 , secondary used in the cathode feedback loop has nothing to do with your setup .
The schematic in Post # 1 can very loosely be considered as a single ended Williamson push pull amplifier.
That is because it has global negative feedback, and . . .
3 low frequency poles:
Two RC couplings from plate to grid
One output transformer with primary inductance.
Get your low frequency poles adjusted, or expect motorboating.
And, watch out for high frequency oscillations too, there does not seem to be a dominant high frequency pole (other perhaps than the output transformer).
Build it with real output transformer and real wiring.
Simulations are often 100% correct, other times you have to do some adjusting of real circuits.
