First post... I've gone down the rabbit hole for a couple of weeks and I'm not getting very far (eyroll)
I borrowed a cheap subwoofer from a friend and managed to very quickly kill it dead (the amplifier hum of death)
https://www.hifi-tower.co.uk/Sound-...rs/18-Active-DJ-PA-Subwoofers-2000W-Pair.html
I am wondering if I can de-activate it (scrap the amplifier) and throw a monster cone into it as a consolidatation.
Something like one of these --->
https://www.loudspeakersplus.com/Eminence-Impero-18C-p/eminence-impero-18c.htm
https://www.loudspeakersplus.com/v/vspfiles/templates/driven/pdfs/Impero_18C.pdf
https://www.cedist.com/sites/defaul...mpero-18c-4-cabinet_design_specifications.pdf
"Ideal for two-way top boxes, full-range two-way boxes, bass guitar boxes, and small subwoofers"
I downloaded WinISD Pro (Alpha) but for some reason it won't accept my numbers and throws an error box.
(Screenshot attached)
I am about to download Hornresp now and see if that fares any better.
Internal dimensions of the box are 610 x 520 x 375
This gives a net volume of 118.95 litres.
Minus 6.70 litres for an Impero 18C, .506 litres of brace and two ports (95mm dia. x 110mm deep) .77 litres each,
giving a combined port volume of just over a litre and a half (1.54l)
Approxamite box volume 110.004 litres
Any help appreciated.... Going back down the rabbit hole.
Databass/
Databass/
WinISD requires a specific inputting order
That said, HR is much more accurate, so better to start with its many 'Wizards'.
OK, so ~42.9 Hz Fb in HR.
Hmm, it can handle all 2400 W > 40 Hz without exceeding Xmax, but the vents are so small it can only handle ~120 W at a ~20 m/s vent mach.
Upping the vent to a 25.4 cm i.d. dia. gets it down to 25 m/s @ 2400W, but length increases to 49.4 cm and takes a 30.48 cm dia. x 67.4 cm to get to ~18 m/s.
Thank you very much for your input, you gave me a few very valuable pointers there (thumbs up)
Okay, I got into WinISD and a night of reading after your posts and I think I might have some solutions.
First off, there is no way that crappy box is getting 2400w, I think maybe 1000w is a bit more realistic.
This improves things greatly.
If I change the port dimensions to 110mm diameter WinISD specifies a port length of 200mm and a port velocity
of almost 35 m/s.
The same parameters adjusted for 120mm diameter round port gives 246.5mm port length and velocity is at 29m/s.
Still a bit high...
How about two larger cut-out right angled triangles instead of round ports.... If I input 1 box port @ 180mm x 180mm
this is technically the surface area of two 180mm x 180mm x 250mm right angled triangles.
Does it work like this, I don't think triangular ports are compatable with WinISD but if it does work, vent length is 330mm
and port velocity is a hair over 20m/s.
That would be perfect I suppose, I could live with that..
Something similar to the design attached below --->
of almost 35 m/s.
Still a bit high...
The usual questions:
IMO, the Eminence driver you're looking at could be bettered by others. I use a few Faital 18XL1800 in my PA, which have an Xmax of 20mm. ie, in the excursion-limited range, they'd match 2.5 of those Eminence drivers.
Output density (dB/L) is where high-end drivers really shine.
Chris
- Budget?
- Do you have an amplifier? If so, how much power?
- Do you have any signal processing?
Chris
Don't sweat it too much... that thing is complete junk.I borrowed a cheap subwoofer from a friend and managed to very quickly kill it dead (the amplifier hum of death)
Yes on using an external amplifier but don't put a different driver in it, the cheap particle board box will just fall apart. The Impero requires a fairly large box to perform decently well as a subwoofer but the box you have as only 4 cu ft, so this combo would not be a great. If you are going to spend money use it on an amplifier.. something that does 500w willl perform about the same as the original plate amp.I am wondering if I can de-activate it (scrap the amplifier) and throw a monster cone into it as a consolidatation.
You're welcome!Thank you very much for your input, you gave me a few very valuable pointers there (thumbs up)
Round is most efficient, so triangular will require longer ones for a given tuning and not supported by any freeware I'm aware of except possibly the old AkaBak.
- Subwoofers
- Is This Worth It ... ?
