Small DIY Driver Gaskets
Thanks for the link. I had a box of the thicker tape, I believe, once.
Perhaps very thin rope caulk would work, a few millimeters thick, if it exists. I’m looking for something smaller for a smaller driver. I’m thinking of gasketing drivers as small as CHN-40 & ScanSpeak 5F.
This past week I started printing gaskets using TPU material on the 3D printer. It really works well. I needed 40 gaskets for some 1" Aurasound Cougar drivers and this was an easy solution. I printed them 0.6 mm thick and using the ironing setting they look good. These needed to be just 2 mm wide in places, so foam tape wasn't an options. I found that a light wipe of olive oil on the print bed made these delicate parts easier to peal up. I have also had good results using poster putty. It will hold a driver in place and can be removed and reused.
Fostex 3" FR gasket is ring-shaped and prone to air leaks, so it is made to fit the frame.
I remember the gaskets being very thin.
I loved my FF85Ks, which were used in my first DIY cabs. They sadly were blown out when my then-toddler daughter cranked up the volume knob when the amp was switched off. I had a surprise when I flipped the switch. The right speaker center cap flew over my shoulder. I laugh about it now. Those were my introduction to single drivers.
