Using PC case switch to power amp on?
I'm using a PC case as an amplifier Chassis.
It has a built in momentary switch which i would like to use to turn the amp on.
Could someone advise me on a fused relay board that would allow me to use this particular button to turn on and off the 230v supply?
If the switch is rated for mains voltage, you can use it to control a latching relay.
Screenshot 2023-07-01 at 23-05-52 41zm7ndMHJL._SX342_.jpg (JPEG Image 342 × 342 pixels).png
Cheers guys
Lol 'russc'. Bit condescending, quite a bit wrong to boot.
Not wrong.
You do need standby power which the board you linked to does provide.
I'm glad you took my comments in good spirit.
It would be useful to outline the amp/power supply you wish to control.
Switchmode supplies or amplifier boards with built in supplies sometimes have provision to put into standby so you only need to mess with the low voltage side.
If you already had the answer, why ask?
