TL with helmholtz @ closed end?
In stead of the standard ‘offset driver’ To kill that second pipe resonance?
(I’m just being a nerd-geek)
the 3000cm2(90 liters) @30 cm and 500cm2 42cm port (~50 hz in the green graph )
verses the 3000cm2 offset at (~1/3) 107cm in 300total.
ID = 54.10
Comment = NEW RECORD - NEW RECORD - NEW RECORD - NEW RECORD - NEW RECORD - NEW RECORD
|RADIATION, SOURCE AND MOUTH PARAMETER VALUES:
Ang = 2.0 x Pi
Eg = 99.00
Rg = 0.00
Fta = 0.00
|HORN PARAMETER VALUES:
S1 = 3000.00
S2 = 3000.00
Par = 30.00
F12 = 0.00
S2S = 500.00
S3 = 500.00
Par = 41.00
F23 = 0.00
S3S = 3000.00
S4 = 3000.00
Par = 263.00
F34 = 0.00
S4S = 0.00
S5 = 0.00
L45 = 0.00
F45 = 0.00
|TRADITIONAL DRIVER PARAMETER VALUES:
Sd = 1680.00
Bl = 33.43
Cms = 4.88E-05
Rms = 14.56
Mmd = 467.35
Le = 1.50
Re = 3.40
OD1 = 2P
|ADVANCED DRIVER PARAMETER VALUES FOR SEMI-INDUCTANCE MODEL:
Re' = 0.00
Leb = 0.00
Le = 0.00
Ke = 0.00
Rss = 0.00
|ADVANCED DRIVER PARAMETER VALUES FOR FREQUENCY-DEPENDENT DAMPING MODEL:
Rms = 0.00
Ams = 0.00
|PASSIVE RADIATOR PARAMETER VALUE:
Added Mass = 0.00
|CHAMBER PARAMETER VALUES:
Vrc = 0.00
Lrc = 0.00
Ap = 0.00
Lpt = 0.00
Vtc = 0.00
Atc = 0.00
Acoustic Path Length = 0.0
|MAXIMUM SPL PARAMETER VALUES:
Pamp = 100
Vamp = 25
Iamp = 4
Pmax = 2000
Xmax = 15.0
Maximum SPL Setting = 3
|ABSORBENT FILLING MATERIAL PARAMETER VALUES:
Fr1 = 0.00
Fr2 = 0.00
Fr3 = 0.00
Fr4 = 0.00
Tal1 = 100
Tal2 = 100
Tal3 = 0
Tal4 = 1
|ACTIVE BAND PASS FILTER PARAMETER VALUES:
High Pass Frequency = 0
High Pass Slope = 1
Low Pass Frequency = 0
Low Pass Slope = 1
Butterworth High Pass Order = 1
Butterworth Low Pass Order = 1
Linkwitz-Riley High Pass Order = 2
Linkwitz-Riley Low Pass Order = 2
Bessel High Pass Order = 1
Bessel Low Pass Order = 1
2nd Order High Pass Q = 0.5
2nd Order Low Pass Q = 0.5
4th Order High Pass Q = 0.5
4th Order Low Pass Q = 0.5
Active Filter Alignment = 1
Active Filter On / Off Switch = 1
|PASSIVE FILTER PARAMETER VALUES:
Series / Parallel 1 = S
Series / Parallel 2 = S
Series / Parallel 3 = S
Series / Parallel 4 = S
|EQUALISER FILTER PARAMETER VALUES:
Band 1 Frequency = 0
Band 1 Q Factor = 0.01
Band 1 Gain = 0.0
Band 1 Type = -1
Band 2 Frequency = 0
Band 2 Q Factor = 0.01
Band 2 Gain = 0.0
Band 2 Type = -1
Band 3 Frequency = 0
Band 3 Q Factor = 0.01
Band 3 Gain = 0.0
Band 3 Type = -1
Band 4 Frequency = 0
Band 4 Q Factor = 0.01
Band 4 Gain = 0.0
Band 4 Type = -1
Band 5 Frequency = 0
Band 5 Q Factor = 0.01
Band 5 Gain = 0.0
Band 5 Type = -1
Band 6 Frequency = 0
Band 6 Q Factor = 0.01
Band 6 Gain = 0.0
Band 6 Type = -1
|STATUS FLAGS:
Auto Path Flag = 0
Lossy Inductance Model Flag = 1
Semi-Inductance Model Flag = 0
Damping Model Flag = 0
Closed Mouth Flag = 0
Continuous Flag = 0
|OTHER SETTINGS:
Filter Type Index = 0
Filter Input Index = 0
Filter Output Index = 0
Filter Type = 2
MEH Configuration = 0
ME Amplifier Polarity Value = 1
ID = 54.10
Ang = 2.0 x Pi
Eg = 99.00
Rg = 0.00
Fta = 0.00
S1 = 3000.00
S2 = 3000.00
Par = 30.00
F12 = 0.00
S2S = 500.00
S3 = 500.00
Par = 41.00
F23 = 0.00
S3S = 3000.00
S4 = 3000.00
Par = 263.00
F34 = 0.00
S4S = 0.00
S5 = 0.00
L45 = 0.00
F45 = 0.00
Sd = 1680.00
Bl = 33.43
Cms = 4.88E-05
Rms = 14.56
Mmd = 467.35
Le = 1.50
Re = 3.40
OD1 = 2P
Re' = 0.00
Leb = 0.00
Le = 0.00
Ke = 0.00
Rss = 0.00
Rms = 0.00
Ams = 0.00
Added Mass = 0.00
Vrc = 0.00
Lrc = 0.00
Ap = 0.00
Lpt = 0.00
Vtc = 0.00
Atc = 0.00
Pamp = 100
Vamp = 25
Iamp = 4
Pmax = 2000
Xmax = 15.0
Fr1 = 0.00
Fr2 = 0.00
Fr3 = 0.00
Fr4 = 0.00
Tal1 = 100
Tal2 = 100
Tal3 = 0
Tal4 = 1
High Pass Slope = 1
Low Pass Slope = 1
Band 1 Gain = 0.0
Band 1 Type = -1
Band 2 Gain = 0.0
Band 2 Type = -1
Band 3 Gain = 0.0
Band 3 Type = -1
Band 4 Gain = 0.0
Band 4 Type = -1
Band 5 Gain = 0.0
Band 5 Type = -1
Band 6 Gain = 0.0
Band 6 Type = -1
|STATUS FLAGS:
Auto Path Flag = 0
Continuous Flag = 0
|OTHER SETTINGS:
Filter Type = 2
yes sir... i think ? or my dumb@ss is chasing my tail 😀
I dunno if Ibe got ‘apples to apples’, but Fb is The same in all of them
(top pic is the straight TL in white and the offset version in green )
