It may be the cheapest in the world. And the excellent performance of 24 BIT 192K
USB TO digital platform. SA9123
SA9123 USB TO SPDIF ,optical , I2S 。
The SA9123L is a high performance up to 24bit,
192KHz PCM streaming USB High-Speed compliant
audio steaming controller. It features one IEC60958
S/PDIF transmit streaming output. The SA9123L is
ideal for both one stereo-in and one stereo-out
professional digital audio interface applications
The SA9123L is high-performance, up to 24 bits,
192KHz PCM Streaming USB High Speed Compatibility
Audio USB controller. It has an IEC60958
S/PDIF transport stream output. SA9123L Yes
Perfect for one stereo input and one stereo output
Professional digital audio interface application
Supported specifications:
Independent sample rates for each
pair
44.1/ 48/ 88.2/ 96/ 176.4/ 192 KHz sampling rates
16/24 bit resolution
It may be the cheapest in the world. And the 32BIT 384K DSD256 with excellent performance
USB TO digital platform. SA9227
And supports AC3 DTS and DSD256
pair
